Re: how to install ddserver on a 3020 tplink router ?
Posted: 16 Mar 2015, 22:04
Thank you to take care of my issue
From my PC wireless, I can access the 3040 with my browser with 192.168.2.1
for the 3020 at 192.168.3.1 it's not possible
Nevertheless during these tests, it was very amazing, I succeeded to have both dslr connected with the following sequence:
- long press 192.168.2.10 allows to connect the dslr connected to the 3020 /actually single press with 192.168.2.1 doesn't work but then automatically it scans at 192.168.2.10 for the next network press.
- single press ( looking again to 2.10 ) allows to connect the dslr connected to the 3040
This sequence from my PC that I connect first to the ddserver wifi I see , the second one with the 3020 is not visible from the PC wifi scan
Then I succeeded again with the same kind of sequence from my nexus 7 tablet.
with the tablet once connected to the wifi network of the 3040, then only one single network press allows to see both dslr, I can see it is looking at 192.168.2.10.
All these information show that I am able to connect, even if it seems that there is something not correct in my rooters parameters.
So either these results show to you where I missed something, and you are able to explain this amazing process?
or I keep like that knowing what I have to do.
Once again, thank you not only for your help, but for this great piece if software
Actually,I edited this post because maybe the keypoint I missed is the switch on the 3020 router, I made almost all my tests with the switch on 3G/4G like on my 3040. then when I succeeded I discovered that the switch was on WISP ! / maybe this explain my issue. I keep it like that !
Best regards
Dominique
Best regards
Dominique
