I am trying to set up the app, everything works fine, but when i set the parameters in live view manual mode, the changing of iso wont effect anything.
the live histogram, and the whole live view screen stays on the same exposure no matter which iso i choose. In A mode i see a much brighter stream.
I would like to use it for video, so it would be important that i see exactly what the sensor sees, so i can set the iso properly.
D610 -changing iso wont effect live view
Re: D610 -changing iso wont effect live view
As far I know ISO change will be visible in live view only on D800, D800E, D810, D4, D4s and D750 models. It is a camera limitation and not an application one.
If the camera is in movie live view mode for Nikon models there is separate ISO control in 'Camera properties display' under the 'Movie' category
i tried theese options also, but nothing. so in this situation there is no point of having live histogram etc?
And it will never work. D610 has no exposure simulation in photo mode.
Switch to movie mode and it will work.
sry for the inaccurate description, but the whole story is about the -movie mode-
i was all over in movie mode, please if someone could test is with a d600/d610, but i cant manage to see what the sensor sees.
its just the aperture which effects directly my live view stream
update: sry, i am to blame
it is working if i set the iso from the menu, not from the bottom left on screen list.
thanks again.
btw could a false color live view filter be implemented?
thanks again.
Will see to add.
