I using the old version of dslrdashboard because when i connect the new version of qDslrDashboard i cant trigger my d610 from an external trigger.
I use an external trigger because i use motion timelapse using emotimo tb3
So my emotimo can tell my camera when he is ready.
If i change host mode on qDslrDashboard my d610 triggers from my emotimo. But then qDslrDashboard won't ramp anymore.
Can this be fixed or is there something i overseen.
Greetings from Tarbax
d610 external trigger
Re: d610 external trigger
If you set qDD to camera host mode you can use only qDD to control it.
Don't know what you mean by "ramping". Camera light meter works always, also exposure parameters change acrding to what camera mode you have selected.
You can also use LRT to control exposure.
