Canon EOS 1100D - DDServer Problem
borg2k
Post by borg2k »
i have two DSLR an EOS 1100D and an EOS 700D. With the EOS 700D qDSLRDashboard works fine on Android and iOS and Wifi/OTG. But the EOS 1100D works only per OTG and Android. Connected to an TP Link MR 3040 it works only until the first autofocus, after that the Camera don`t respond to an command from the qDSLRDashboard App, the same result on Android and iOS. After autofocus i can´t change any setting like iso, aperture...
I think it´s a problem by the ddserver.
Re: Canon EOS 1100D - DDServer Problem
Do you have the latest DDServer V0.2-13
You can check in OpenWrt web interface (http://192.168.1.1) under System->Software
When it does crash with EOS1100D please check the Status->System log
There should be some ddserver messages that may help determine the problem
