Latest qdslrdashboard and multiple cameras with MR3040 and USB hub
kevinbuckley70
Post by kevinbuckley70 »
I'm trying to connect two Nikon D90's using MR3040 and USB hub.
qdslrdashboard reports two cameras - but it's the same camera (shows same name and IP for both).
If I just connect one camera through the hub it works fine - it can see whichever camera is connected.
When I connect the second camera, it reports two cameras to choose from, but they are both the same camera.
Do I need to change the IP address of the camera's manually? Or rename them? How?
Any help appreciated!
kevinbuckley70
Re: Latest qdslrdashboard and multiple cameras with MR3040 and USB hub
Fixed it!!
There's a setting: 'Connect to all detected DSLR' in qdslrdashboard. Default if not ticked. If you tick that, it works!
