5D Mark II + Ipad air + USB or wireless
alex
Post by alex »
Hi, is it possible to connect the 5DMII to Ipad air via OTG?
If not, which would be the best approach to do it via wifi with this combo 5DMII + Ipad air?
Many thanks!
Re: 5D Mark II + Ipad air + USB or wireless
iPhones and iPads don't have USB port so you cannot connect with it. Only and you have only one approach - WiFi mobile router with USB port and OpenWRT.
The easiest way is to use TP-Link MR3040 or Hame MPR-A2 for which Zoltan made OpenWRT firmware with ddserver.
alex
Post by alex »
OK. Great Many thanks, Gonzo. Just placed the order for the TP-Link. So when I receive it I get OpenWRT and deserver into it. right?
Cheers!
With MR3040 you just flash fw made by which has ddserver in it. Whole manual how to do is on qDD page:
Http://dslrdashboard.info/tp-link-mr3040-openwrt-flash/
And fw (2 files) is on downloads page:
Http://dslrdashboard.info/downloads/
alex
Post by alex »
Great, many thanks, again, Gonzo!
alex
Post by alex »
Hi, I got the TP-link. Version 2.4 (label in box), I already downloaded the version 2 file. Following instructions, but when I try: http://192.168.0.1 on a tab on my browser it just tries to connect or something but nothing happens, after a while I get "webpage not available". Tried with different browsers and nothing. Its connected via ethernet and the ethernet light in the TP-link is on.
Anyone know what could it be? Many thanks!
cathy
Post by cathy »
alex
Post by alex »
Got it, many thanks! Im on a Mac, had to go the manual route on the ethernet connection. All good now and working. Will be running tests upcoming week.
Cheers! :)
