can not connect to 5Dmk3 via ios device(iPad2)
Hello, I am a new user of qDeslrDashboard. Took awhile to update new firmware (ddserver_openwrt-tl-mr3040-v1-squashfs-factory_0.13.bin) into new TP-Link MR3040 wifi router by following the tutorial. But can not connect 5D3 via qDslrDashboard ios app v 2.0.5 on iPad 2. push the Wifi-symbol button and "searching for DDServer" appear on the bottom of the screen , then nothing happened. Any helps will be appreciate.
Re: can not connect to 5Dmk3 via ios device(iPad2)
You need to click the 'Network' button (the first one)
The wireless buttons are only for cameras that have built in wireless.
Please check the manual available at: http://dslrdashboard.info/downloads/
Hi Hubaiz,
Thanks for the prompt response, I did push the "network" button, still can not connect to 5D3. not sure where went wrong. I can see MR3040(DDServerAP) from the wifi list on my device's wifi setting page.
I will check the menu a little bit later, in the mean time if you can think of any solution, please advice. Thanks again.
Hi Hubaiz,
It worked now, I reconnect every cords, and restart MR3040 then turn on 5D3, it can connect to 5D3 now. Thanks for the help.
