can not connect to 5Dmk3 via ios device(iPad2)
Posted: 31 Mar 2015, 08:40
by dipaul
Hello, I am a new user of qDeslrDashboard. Took awhile to update new firmware (ddserver_openwrt-tl-mr3040-v1-squashfs-factory_0.13.bin) into new TP-Link MR3040 wifi router by following the tutorial. But can not connect 5D3 via qDslrDashboard ios app v 2.0.5 on iPad 2. push the Wifi-symbol button and "searching for DDServer" appear on the bottom of the screen , then nothing happened. Any helps will be appreciate.
Re: can not connect to 5Dmk3 via ios device(iPad2)
Posted: 31 Mar 2015, 09:20
You need to click the 'Network' button (the first one)
The wireless buttons are only for cameras that have built in wireless.
Please check the manual available at:
http://dslrdashboard.info/downloads/
Posted: 31 Mar 2015, 09:58
by dipaul
Hi Hubaiz,
Thanks for the prompt response, I did push the "network" button, still can not connect to 5D3. not sure where went wrong. I can see MR3040(DDServerAP) from the wifi list on my device's wifi setting page.
I will check the menu a little bit later, in the mean time if you can think of any solution, please advice. Thanks again.
Posted: 31 Mar 2015, 10:30
by dipaul
Hi Hubaiz,
It worked now, I reconnect every cords, and restart MR3040 then turn on 5D3, it can connect to 5D3 now. Thanks for the help.
