First, thank you for having written qDslrDashboard, it's super cool.
I tried to use the Interval Controller in order to control the NMX motion controller and use the wifi remote shutter on my Nikon D750. Unfortunately the NMX does not want to move once I start the timer. Everything works fine before that, I can move the slider, set the operators along the timeline, when I start the timer, the camera takes pictures correctly, but nothings move. I have the latest firmware (0.46 Beta) on the NMX, I tried on iOS and OS X with the same result.
Any idea of what might be the problem?
I included a screenshot (without the camera wifi connection).
Interval controller not moving the NMX
- Screenshot 2016-01-08 14.34.32.png (213.36 KiB) Viewed 4370 times
Re: Interval controller not moving the NMX
What you mean under the 'wifi remote shutter' ?
Your slider didn't move as there was no notification when to do it.
One way is by using the connected camera as a capture finished notification.
The other is by checking the 'Capture finished' checkbox.
