[Solved] 0.3.4 Unable to start on Raspbian
Posted: 16 Jan 2016, 20:20
I really wanted to avoid making a forum post about this, since most of the problems resolve after a bit of google-research But that didn't really do the job, so I'm hoping for some help here.
As the title already implies, I can't run qDslrDashboard on my RPi 2b. This is the error I'm getting when trying to start the qDslrDashboard.sh file:
Before I made a link to /lib/arm-linux-gnueabihf/libudev.so.0.13.0 with the name libudev.so.1, I got this error:
Both the libc.so.6 and libgomp.so.1 are there, so I suspect it's some kind of version issue.
This is the uname -a output, just in case:
Older versions of qDslrdashboard worked (I don't remember the exact version), but they don't seem to be available anymore.
Anyways, hope someone can help me with my little problem, thanks in advance!
/home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2# /home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./qDslrDashboard: /lib/arm-linux-gnueabihf/libudev.so.1: no version information available (required by /home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/libusb-1.0.so.0)
/home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./qDslrDashboard: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.17' not found (required by /home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/libusb-1.0.so.0)
/home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./qDslrDashboard: /usr/lib/arm-linux-gnueabihf/libgomp.so.1: version `GOMP_4.0' not found (required by /home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/libraw.so.15)
/home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./qDslrDashboard: /lib/arm-linux-gnueabihf/libudev.so.1: no version information available (required by /home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/libQt5SerialPort.so.5)Code: Select all
/home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./qDslrDashboard: error while loading shared libraries: libudev.so.1: cannot open shared object file: No such file or directory
Linux raspberrypi 4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015 armv7l GNU/LinuxAnyways, hope someone can help me with my little problem, thanks in advance!
