D3300 via USB3
N6REJ
D3300 via USB3
Post by N6REJ »
I'm having a problem where its not seeing the d3300 even though the pc see's it and windows photo's works perfectly with it.
Win 10 already includes the winusb driver natively. And it is being loaded for that port.
When I click on the #1 icon nothing happens.
What should I do?
device manager driver details
Re: D3300 via USB3
All windows from XP have winusb driver but use WUDFRd which needs to be changed to winUSB.
With out this qDD won't see camera.
MARTIN
Re: D3300 via USB3
Post by MARTIN »
I have the same problem. How can I change WUDFRd into winUSB ?
Thank you for your answer.
Re: D3300 via USB3
MARTIN
Re: D3300 via USB3
Post by MARTIN »
OK I foolow the instructions with Zadig and I have the message that the winusb is correct installed.
But when I launch dslrdashboard, I have the message that Windows locked the access to the private net. But I authorize the access.
Next when I click on the button "USB connection" I have an errror message and I have to close the application.
Thanks for your help
Re: D3300 via USB3
Do you use the V0.3.4 fix (http://dslrdashboard.info/downloads/)
MARTIN
Re: D3300 via USB3
Post by MARTIN »
I used the version qDslrDashboard_V0.3.4_Windows_x64 because I have windows 10.
Now with the file .exe of the v0.3.4 fix and the other files of qDslrDashboard_V0.3.4_Windows_x64, I have no problem and all is working. Thank you very much but I don(t understand why I have to mix files from different downloads.
Now I can explore and use your software and certainly I'll take the Android version and hope that all will be OK.
Thanks.
