Github repositories
Github repositories
Are the GitHub repos up to date? I assume DslrDashboard might not be but how about ddserver?
Re: Github repositories
DslrDashboardServer is up to date.
Is there anyway to cache the images captured by camera through ddserver to stay on ddserver device to ftp upload the files to an ftp server ?
Dave
Dave
No, the ddserver is only a proxy application that forwards PTP packets between the USB connected DSLR and qDslrDashboard over network.
Alright, thank you. I cross compiled it without major problems under Jessie together with OpenWrt Designated Driver r48510. Had to include a new shared library via under libs in the Makefile.
I have been using it for an hour and it works great. I was not sure if that's really worth a pull request so I mention it here.
-lgcc_sI have been using it for an hour and it works great. I was not sure if that's really worth a pull request so I mention it here.
