I installed both x86 and x86_XP on my windows7 machine. First installed, then the vc... file then applied the fix. Even XP SP3 Mode.
The programm starts but takes like 10 seconds to display the top buttons. Takes 5 Seconds to change the frame when I hover the buttons.
(I use OpenWRT connection) If I long-press the network button, only the "9" and "8" of 192.168.1.1 are displayed, I changed it blindly to my configuration 192.168.3.1, works and connects fine! Still unusably slow which results in no LiveView displayed. What is it that I'm doing wrong?
Thanks for help people, appreciate it.
BTW the android app works perfectly fine. Thanks for the great work!
Cheers Sutider
