Connection ddserver qdslrdashboard windows10
Posted: 11 Feb 2016, 16:32
Hallo, please need help. I installed openwrt on TP-Link TL-WR710N v1 and konfigured wlan as client with dchcp as all other devices in same lan and adress range. Close firewall make it open for everything. installed usb -utils an could get answer with lsusb like : Bus 001 Device 002: ID 04b0:042c Nikon Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub . all seems ok. I installed all new packages needed for ddserver: libpthread_1.1.12-1_ar71xx; librt_1.1.12-1_ar71xx; libusb-1.0_1.0.19-1_ar71xx; uclibcxx_0.2.4-2_ar71xx and last version of ddserver_0.2-13_ar71xx.ipk . All ipk´s as last versions i could find. Now i installed on windows 10 the prog qDslrDashboard_V0.3.4_Windows_x64. It runs great with my nokia d3200 locked in on usb, but i could not reach the ddserver on the tp-link router. The correct ip-adress with default port is given in. Both - windows and ddserver do not recognizes each other. Where is the problem? what can i do? ddserver starts fine with ./ddserver start in /etc/init.d and gives out the message: Starting DslrDashboardServer (ddserver)
Saving PID 2337 to /var/run/ddserver.pid
DslrDashboard server started
root@OpenWrt:/etc/init.d#
thanks for any help
thanks for any help
