I'm not sure if this is tied to the latest firmware i just put on my nikon d5500 but it doesnt seem to connect over the wifi from the camera. the nikon wireless app seems to work ok. the screen is just black and doesnt switch to liveview on the app. i tap the nikon icon in the top of the app and nothing happens, long press and make sure the ip is correct and nothing happens. i got the app to crash a couple times but do not have a logcat of that. not sure of what other info to provide
I am getting the following in a logcat
02-21 13:45:08.612 817 3379 I ActivityManager: START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=info.qdd/.DslrDashboard (has extras)} from uid 10030 on display 0
02-21 13:45:08.688 8105 8105 W qDslrDashboard: (null):0 ((null)): Can't find surface 3
02-21 13:45:08.704 8105 8105 W qDslrDashboard: (null):0 ((null)): Can't find surface 3
02-21 13:45:41.659 8105 8134 D qDslrDashboard: qrc:/qml/qml/main.qml:152 (onActiveFocusChanged): qml: managerOverlayLoader active focus changed false
02-21 13:45:41.659 8105 8134 D qDslrDashboard: qrc:/qml/qml/components/ScreenManagerOverlay.qml:12 (onActiveFocusChanged): qml: manager overlay got focus false
02-21 13:45:41.659 8105 8134 D qDslrDashboard: qrc:/qml/qml/components/ScreenManagerOverlay.qml:108 (onActiveFocusChanged): qml: button active focus changed false index 0
02-21 13:45:41.665 8105 8134 D qDslrDashboard: qrc:/qml/qml/main.qml:266 (onActiveFocusChanged): qml: messagUi activeFocus true
02-21 13:45:42.690 8105 8134 D qDslrDashboard: qrc:/qml/qml/main.qml:152 (onActiveFocusChanged): qml: managerOverlayLoader active focus changed true
02-21 13:45:42.690 8105 8134 D qDslrDashboard: qrc:/qml/qml/components/ScreenManagerOverlay.qml:12 (onActiveFocusChanged): qml: manager overlay got focus true
02-21 13:45:42.690 8105 8134 D qDslrDashboard: qrc:/qml/qml/components/ScreenManagerOverlay.qml:108 (onActiveFocusChanged): qml: button active focus changed true index 0
02-21 13:45:42.690 8105 8134 D qDslrDashboard: qrc:/qml/qml/main.qml:266 (onActiveFocusChanged): qml: messagUi activeFocus false
02-21 13:45:42.692 8105 8134 D qDslrDashboard: qrc:/qml/qml/main.qml:152 (onActiveFocusChanged): qml: managerOverlayLoader active focus changed false
02-21 13:45:42.692 8105 8134 D qDslrDashboard: qrc:/qml/qml/components/ScreenManagerOverlay.qml:12 (onActiveFocusChanged): qml: manager overlay got focus false
02-21 13:45:42.692 8105 8134 D qDslrDashboard: qrc:/qml/qml/components/ScreenManagerOverlay.qml:108 (onActiveFocusChanged): qml: button active focus changed false index 0
02-21 13:45:42.710 8105 8134 D qDslrDashboard: qrc:/qml/qml/main.qml:31 (onDestruction): qml: windows destroyed
02-21 13:45:42.710 8105 8134 D qDslrDashboard: qrc:/qml/qml/screen/DeviceScreen.qml:23 (onDestruction): qml: DeviceScreen destroyed
02-21 13:45:42.713 8105 8134 D qDslrDashboard: qrc:/qml/qml/core/ScreenBase.qml:22 (onDestruction): qml: ScreenBase destroyed
02-21 13:45:42.937 817 2660 I InputReader: Reconfiguring input devices. changes=0x00000004
02-21 13:45:42.938 817 2660 I InputReader: Device reconfigured: id=5, name='synaptics-rmi-ts', size 1080x1920, orientation 0, mode 1, display id 0
02-21 13:45:42.939 817 2777 I ActivityManager: Config changes=480 {1.0 310mcc410mnc en_US ldltr sw360dp w360dp h616dp 480dpi nrml long port finger -keyb/v/h -nav/h s.15 themeResource=null}
02-21 13:45:43.015 3215 3215 I Keyboard.Facilitator: onFinishInput()
02-21 13:45:43.069 8105 8105 I art : System.exit called, status: 0
02-21 13:45:43.069 8105 8105 I AndroidRuntime: VM exiting with result code 0, cleanup skipped.
02-21 13:45:43.082 817 2807 I WindowState: WIN DEATH: Window{692b409 u0 SurfaceView}
02-21 13:45:43.082 817 3419 D GraphicsStats: Buffer count: 6
02-21 13:45:43.084 817 3379 I WindowState: WIN DEATH: Window{a515389 u0 info.qdd/info.qdd.DslrDashboard}
nikon d5500 wont connect
Re: nikon d5500 wont connect
The latest Nikon firmware update for D5300 and D5500 will probably crash qDslrDashboard on Android .
There is a fix in work/testing.
Just saw the update in the play store, will play with it the next chance I get which will be tomorrow morning most likely. Thank you so much for the fast response, much appreciated.
I'm having much the same problem with my D 7200. Nikon's app works fine but I only get a black screen. I have only just purchased the software.
Just wanted to close this up as fixed for me in a later version of the app. thanks for the quick response!
