Support for Custom (C) mode
steinardo
Post by steinardo »
I tried saving my typical timelapse settings to the custom dial on my EOS camera. But trying to use this C mode in qDD did not work - it was requesting the M mode (even though the M setting was stored within the C mode).
Would it be possible to support C mode - as I typically have other settings during normal photography, it would be convenient to just dial to C for timelapse?
Re: Support for Custom (C) mode
I will try to add it, the 70D has a C settings so I can test it.
rega
Post by rega »
Hi Zoltan,
I've exactly the same request. It would be very convenient if QDDB would support Canon Custom mode as they are specifically done for storing a specific set of parameters, just when shooting time lapses.
best regards!
