I am having issues connection a nikon d5100 with Ipad. The camera connects with Mac through USB cable and works fine with dslrdashboard software.
But I have issues connecting it wirelessly using the wifi router.
I have updated the TPlink to the latest WRT firmware and also updated the ddserver to the latest version.
How do I run a diagnostic to know the issue is?
Cheers!
Connection Issue (TPLink MR3040 - nikon d5100 - Ipad)
Re: Connection Issue (TPLink MR3040 - nikon d5100 - Ipad)
What issues do you have?
Can you access the OpenWrt web interface from iPad (http://192.168.1.1)?
Have you installed clean OpenWRT and just ddserver ?? Or have you also installed other necessary libraries??rkc wrote: I have updated the TPlink to the latest WRT firmware and also updated the ddserver to the latest version.
If just clean OpenWRT and ddserver, than you have done it wrong. Download and flash firmware prepared by Zoltan and it will work.
