I am fighting with the wireless solution. Wired via usb cable it's fine. But if I wanna use the TP router I don't get establisehd a connection in dslrdashboard.
I got the finalized router which has the openwrt on it outof the box.
But: no "plug'n'play"
I have tested this on diffrent android tablets and a smartphone - all of them with diffrent android version. In my point of view this is not a problem with android.
I can establish the wireless connection but dslrdashboard find no cam. Also I have found here a "solution" in this board which should work. It doesn't for me..
A crazy thing is: in diffrent tutorials on the net they told that the switch (I have the v2 version of this router) on the side has to set to 3g..not to AP. But this doesn't work in my oppinion. I have check this with set to AP. Then I get a connection wireless to the router. But if I set the router to 3g then I lost the connection.
Because of this problems I have changed the software on the router with yours fron your DL area. Same problem.
What can I do??
Thanks.
Regards
Nikonboy
D3300
TPlink v2 M3040
Dslrdashboard from playstore (non free version)
