Page 1 of 2
Connection with TP M3040 Problem
Posted: 24 Mar 2016, 06:31
by nikonboy
Hi @all
I am fighting with the wireless solution. Wired via usb cable it's fine. But if I wanna use the TP router I don't get establisehd a connection in dslrdashboard.
I got the finalized router which has the openwrt on it outof the box.
But: no "plug'n'play" :?
I have tested this on diffrent android tablets and a smartphone - all of them with diffrent android version. In my point of view this is not a problem with android.
I can establish the wireless connection but dslrdashboard find no cam. Also I have found here a "solution" in this board which should work. It doesn't for me..
A crazy thing is: in diffrent tutorials on the net they told that the switch (I have the v2 version of this router) on the side has to set to 3g..not to AP. But this doesn't work in my oppinion. I have check this with set to AP. Then I get a connection wireless to the router. But if I set the router to 3g then I lost the connection.
Because of this problems I have changed the software on the router with yours fron your DL area. Same problem.
What can I do??
Thanks.
Regards
Nikonboy
D3300
TPlink v2 M3040
Dslrdashboard from playstore (non free version)
Re: Connection with TP M3040 Problem
Posted: 24 Mar 2016, 06:39
After pairing/connecting your device wireless with the MR3040 wireless:
In a web browser open the OpenWrt administration page ( http://192.168.1.1 )
Navigate to System->Software and locate the 'ddserver' package. Do you have it? It should be V0.2-13
Connect your DSLR with USB cable to the full size USB port on the MR3040 and turn it on.
Navigate to Status->System log and at the end you should have something like (ignore the incorrect date/time):
Mar 24 07:15:46 Arduino kern.info kernel: [3009062.910000] usb 1-1.1.4: USB disconnect, device number 81
Mar 24 07:15:47 Arduino kern.info kernel: [3009063.670000] usb 1-1.1.3: USB disconnect, device number 80
Mar 24 07:38:48 Arduino kern.info kernel: [3010444.530000] usb 1-1.1.4: new high-speed USB device number 82 using ehci-platform
Mar 24 07:38:48 Arduino kern.info kernel: [3010444.640000] usb 1-1.1.4: New USB device found, idVendor=04b0, idProduct=0430
Mar 24 07:38:48 Arduino kern.info kernel: [3010444.640000] usb 1-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 24 07:38:48 Arduino kern.info kernel: [3010444.640000] usb 1-1.1.4: Product: NIKON DSC D7100
Mar 24 07:38:48 Arduino kern.info kernel: [3010444.650000] usb 1-1.1.4: Manufacturer: NIKON
Do you have this?
Posted: 24 Mar 2016, 06:52
by nikonboy
Hi.
Thanks for quick responsr.
YES..Version is the same as you mentioned beforr.
BUT: system log shows nothing with actual dat/time??? :shock:
Posted: 24 Mar 2016, 06:54
by nikonboy
To which point I have to set the switch : AP or WISP ?
Actual it is set to AP..
Posted: 24 Mar 2016, 07:03
by nikonboy
ok. wait. I have seen, the date/time on my router is not important.
I have powered off and on the cam..
This is a snip from the log:
Sep 8 15:48:17 OpenWrt kern.info kernel: [ 264.980000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Sep 8 15:48:45 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPINFORM(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0
Sep 8 15:48:45 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPACK(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0 PC1
Sep 8 15:49:47 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPINFORM(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0
Sep 8 15:49:47 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPACK(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0 PC1
Sep 8 15:52:28 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPINFORM(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0
Sep 8 15:52:28 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPACK(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0 PC1
Sep 8 15:53:30 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPINFORM(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0
Sep 8 15:53:30 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPACK(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0 PC1
Sep 8 15:54:22 OpenWrt kern.info kernel: [ 630.310000] usb 1-1: USB disconnect, device number 2
Sep 8 15:54:29 OpenWrt kern.info kernel: [ 637.560000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Sep 8 15:54:55 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPINFORM(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0
Sep 8 15:54:55 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPACK(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0 PC1
Sep 8 15:56:00 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPINFORM(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0
Sep 8 15:56:00 OpenWrt daemon.info dnsmasq-dhcp[932]: DHCPACK(br-lan) 192.168.1.174 18:3d:a2:1b:df:b0 PC1
Posted: 24 Mar 2016, 09:59
by GonzoG
Have you flashed both files ?? (factory and sys-upgrade)
If no then flash them again, than connect camera and check log.
Posted: 24 Mar 2016, 16:11
by nikonboy
Hi
I did it as you have mentioned.
I have updated both software - firmware AND systemsoftareupdate
The same problem as before ;) :cry:
In which position the switch at the MR3040 has to be set ..
to upgrade firmware - 3g/4g, AP oder WISP?
to use ist with the dslrdahsboard? I found some tutorials where they told one time to set to 3g/3g and one time AP.
Any other ideas? The system log is as before .. no diffrence, no camera, no ardunio kernel ...
Posted: 24 Mar 2016, 20:54
by nikonboy
I tried flashing again, diffrent ways to start all components.. Are there any other options to check the communication?
Can I change the port from the IP? Does this standardport work with D3300? The crazy thing is with USB is all ok... :evil:
But again the question, in which mode has to the router for flashing and then for work? AP? WISP? 3G/4G?
Posted: 24 Mar 2016, 21:09
by GonzoG
Mode switch does not work with OpenWRT so it can be in any position.
The IP and port are for ddserver. Have nothing to do with camera. If camera works with USB it should work with MR3040. You have to only change defalut IP in qDD (long press on network button) if your MR3040 uses other than 192.168.1.1
Posted: 25 Mar 2016, 03:31
by nikonboy
Ok. Are therevany other ideas/suggestions? Is the original otg cable from the camera the problem? Are ther other options which I can check that thd firmware / sysupgrade both correct installed? Is it possible to reset the router completely and to start from beginning?
The switch is an intrresting thing.I lost connection if the switch is not in AP mode.
