Holy grail Sony A7s, raw+jpeg problem
marc122
Post by marc122 »
I use a Sony A7s and want to do day to Night timelapses. The Control of Camera Settings in LRT mode worked when i used jpeg for the photos. When I change to raw+jpeg (small jpeg) in the Camera Settings, the Image in the screen does Not appear as if it wants to read the raw file, Black Monitor.
When I use the normal intervalometer within the app, it works with raw+jpeg, also the preview appears. Even Change of Settings at the Same Time Interval is possible (but all manual then...)
Anyone has seen this before or has a solution for that? Am I missing something?
Thank you.
Marc
marc122
Re: Holy grail Sony A7s, raw+jpeg problem
Post by marc122 »
I just figured out that i have the Problem only with the iOS App. Working with my Windows Tablet raw+jpeg Works.
marc122
Post by marc122 »
I just figured out that when working with my Microsoft Surface Tablet, everything works Great. Maybe it has something to do with the iOS App.
Both platforms use the same code.
Check that you can change the settings manually (shutter, aperture, iso).
On Sony if you do a manual focus select in the live view image it will no allow you to change any of the settings only capture is possible. In qDslrDashboard you must press the AF button to exit this 'focus mode'
