Just installed DslrDashboard on Win10 and cant run because of OpenGL error. error says i need OpenGL2.0 or higher, i have ver3.1?
What do i need to get the app to run?
cheers
Win10 Opengl error
Re: Win10 Opengl error
same problem here using win7. I didn't have problems with previous releases (0.3.4).
What graphics card do you have? Does it have the latest drivers?
Intel HD 3000. Should be the latest driver. I did't change anything in the driver configuration lately.
According this: https://communities.intel.com/thread/37 ... 0&tstart=0
Intel HD 3000 supports OpenGL 2.1 just needs the latest driver.
What is the exact error you get? A screen shot maybe?
i check again and installed latest intel drivers. Problem still the same. I included a screenshot..
- 2016-04-26 09_13_52-(1) dslrdashboard.info - Post a reply.png (19.43 KiB) Viewed 15533 times
Depending on the system you have unpack the x86 or x64 folder contents to your qDslrDashboard folder from this archive: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
There are 3 files:
libEGL.dll
libGLESv2.dll
opengl32sw.dll
The files should be in the same folder as qDslrDashboard.exe
After unpacking start qDslrDashboard.
There are 3 files:
libEGL.dll
libGLESv2.dll
opengl32sw.dll
Problem solved! Thanks for you support, Zoltan.
Donation is already on the way.
Just an explanation.
By default qDD will try and use OpenGL (for this it needs V2.1)
If this fails it will try to use the following libraries:
libEGL.dll
libGLESv2.dll
These 2 will try and translate the OpenGL calls into DirectX calls.
If this fails then the
opengl32sw.dll
will be used. This is a OpenGL software renderer.
libEGL.dll
libGLESv2.dll
opengl32sw.dll
