TL-MR3040 connection problem
Posted: 20 Apr 2016, 05:58
by leontsai2002
Hi
I had the TL-MR3040 V.1 machine and I follow the instruction to flash the firmware into the wifi module
It works but every time I power off and power on the MR-3040 again, I could not connect to the MR-3040 anymore
the only solution I find is to reflash the MR-3040 again
Anyone know why?
Re: TL-MR3040 connection problem
Posted: 20 Apr 2016, 07:03
You don't see the wireless access point ('DDServerAP' by default) ?
Posted: 20 Apr 2016, 09:56
by leontsai2002
I could connect to the DDSeverAP hotspot, but the app just can't connect to the camera.
But if I reflash the MR-3040 software ,the app could connect to the camera and work well.
Sadly, Everytime I power off the MR-3040 and Power it on again, the app just can't connect to the camera anymore...
Posted: 20 Apr 2016, 10:59
Does it work if you long press the 'Network' button and enter 192.168.1.1 in the upcoming dialog and finally press the 'Ok' button?
Posted: 20 Apr 2016, 15:23
by leontsai2002
No,I did what you say and still could not connect to the camera
But If I reflash the software,short press the network button will connect to the camera right away.........
