Hi
I had the TL-MR3040 V.1 machine and I follow the instruction to flash the firmware into the wifi module
It works but every time I power off and power on the MR-3040 again, I could not connect to the MR-3040 anymore
the only solution I find is to reflash the MR-3040 again
Anyone know why?
TL-MR3040 connection problem
Re: TL-MR3040 connection problem
You don't see the wireless access point ('DDServerAP' by default) ?
leontsai2002
I could connect to the DDSeverAP hotspot, but the app just can't connect to the camera.
But if I reflash the MR-3040 software ,the app could connect to the camera and work well.
Sadly, Everytime I power off the MR-3040 and Power it on again, the app just can't connect to the camera anymore...
Does it work if you long press the 'Network' button and enter 192.168.1.1 in the upcoming dialog and finally press the 'Ok' button?
leontsai2002
No,I did what you say and still could not connect to the camera
But If I reflash the software,short press the network button will connect to the camera right away.........
