Hello
I can`t get a connection to the 5DIII ..Firmware 1.3.3.
It not work withe a IPhone 6S and macOSX 10.11.14
Here are the last Sytem Logs
Fri Oct 18 08:18:41 2013 authpriv.info dropbear[995]: Not backgrounding
Fri Oct 18 08:21:24 2013 kern.info kernel: [ 213.680000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Fri Oct 18 08:21:46 2013 daemon.info hostapd: wlan0: STA cc:20:e8:2a:21:0a IEEE 802.11: authenticated
Fri Oct 18 08:21:46 2013 daemon.info hostapd: wlan0: STA cc:20:e8:2a:21:0a IEEE 802.11: associated (aid 2)
Fri Oct 18 08:21:46 2013 daemon.info hostapd: wlan0: STA cc:20:e8:2a:21:0a WPA: pairwise key handshake completed (RSN)
Fri Oct 18 08:21:46 2013 daemon.info dnsmasq-dhcp[931]: DHCPREQUEST(br-lan) 192.168.1.196 cc:20:e8:2a:21:0a
Fri Oct 18 08:21:46 2013 daemon.info dnsmasq-dhcp[931]: DHCPACK(br-lan) 192.168.1.196 cc:20:e8:2a:21:0a iPhonevichNatge
Fri Oct 18 08:22:18 2013 daemon.info hostapd: wlan0: STA e4:ce:8f:68:2c:59 IEEE 802.11: disassociated
Fri Oct 18 08:22:19 2013 daemon.info hostapd: wlan0: STA e4:ce:8f:68:2c:59 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Fri Oct 18 08:22:44 2013 daemon.info hostapd: wlan0: STA e4:ce:8f:68:2c:59 IEEE 802.11: authenticated
Fri Oct 18 08:22:44 2013 daemon.info hostapd: wlan0: STA e4:ce:8f:68:2c:59 IEEE 802.11: associated (aid 1)
Fri Oct 18 08:22:44 2013 daemon.info hostapd: wlan0: STA e4:ce:8f:68:2c:59 WPA: pairwise key handshake completed (RSN)
Fri Oct 18 08:22:45 2013 daemon.info dnsmasq-dhcp[931]: DHCPREQUEST(br-lan) 192.168.1.125 e4:ce:8f:68:2c:59
Fri Oct 18 08:22:45 2013 daemon.info dnsmasq-dhcp[931]: DHCPACK(br-lan) 192.168.1.125 e4:ce:8f:68:2c:59 Ulrichs-iMac
Fri Oct 18 08:28:15 2013 daemon.info hostapd: wlan0: STA e4:ce:8f:68:2c:59 WPA: group key handshake completed (RSN)
Fri Oct 18 08:28:16 2013 daemon.info hostapd: wlan0: STA cc:20:e8:2a:21:0a WPA: group key handshake completed (RSN)
Fri Oct 18 08:38:15 2013 daemon.info hostapd: wlan0: STA cc:20:e8:2a:21:0a WPA: group key handshake completed (RSN)
Fri Oct 18 08:38:15 2013 daemon.info hostapd: wlan0: STA e4:ce:8f:68:2c:59 WPA: group key handshake completed (RSN)
Fri Oct 18 08:40:14 2013 kern.info kernel: [ 1343.830000] usb 1-1: USB disconnect, device number 2
Fri Oct 18 08:40:31 2013 kern.info kernel: [ 1361.010000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Fri Oct 18 08:40:32 2013 kern.info kernel: [ 1361.610000] usb 1-1: USB disconnect, device number 3
Wed Apr 20 18:47:41 2016 daemon.info hostapd: wlan0: STA e4:ce:8f:68:2c:59 WPA: group key handshake completed (RSN)
Wed Apr 20 18:47:41 2016 daemon.info hostapd: wlan0: STA cc:20:e8:2a:21:0a WPA: group key handshake completed (RSN)
Wed Apr 20 18:49:28 2016 kern.info kernel: [ 1800.800000] usb 1-1: new high-speed USB device number 4 using ehci-platform
Wed Apr 20 18:57:41 2016 daemon.info hostapd: wlan0: STA e4:ce:8f:68:2c:59 WPA: group key handshake completed (RSN)
Wed Apr 20 18:57:42 2016 daemon.info hostapd: wlan0: STA cc:20:e8:2a:21:0a WPA: group key handshake completed (RSN)
no conection to 5DIII
Re: no conection to 5DIII
I am using same config as you have, connection works perfect for me. I have iPhone 6s and iPAD mini. Assume you are using TP MR3024 link? I followed Zoltan's tutorial.
https://www.youtube.com/watch?v=Our-Axm ... freload=10
Cheers Horst
Cheers Horst
Connect your DSLR with USB cable to the MR3040 full size USB port and turn it on.
Connect/pair your controlling device (iOS/OSX) wireless to the MR3040 wireless.
Start qDslrDashboard and press the 'Network' button (on iOS the first button from left, on OSX the second button from left).
If the camera is not found you can try and long press the 'Network' button and in the upcoming dialog enter the MR3040 IP address (by default 192.168.1.1) and press the 'Ok' button.
