Not working on meizu m2 note
viteo
Post by viteo »
I tried everything after buying the app, but with bad luck. First i tried to connect my 60d on laptop, windows, and it works really fine. Then, after checking both cables, usb, and otg (I even tried to connect kingston 32gb usb by otg and it works..) I downloaded the app, and played with the settings but nothing worked out.. was clicking on the first button.. nothing.. Device is rooted, and you can see everything from ss..
https://drive.google.com/open?id=0B_a9R ... 2NOZm1wZ00
Re: Not working on meizu m2 note
Does the meizu m2 note has full USB host function? You can try and check with the following application: https://play.google.com/store/apps/deta ... iagnostics
