Cache for images on camera and mobile device
disgustiapted
It would be nice to be able to have some sort of cache on the mobile device so that when you browse the images on the camera it doesn't have to sit there for a couple of minutes while it's reading all of the files on the camera. I can understand the complexities of this where if there were same file names but different images on the camera or if the image had been removed from the camera through another means. I also imagine it's somewhat dependent on the API that Nikon has to pull images over wifi.
Re: Cache for images on camera and mobile device
Before you can synchronize your local cache with the camera SD card you need to fetch the image infos so you do not gain anything.
