NMX Controller + QDSLRDASHBOARD via Ethernet
Posted: 26 Apr 2016, 20:26
by flow85
Hy,
is it possible to connect the NMX Controller via Ethernet Cable to any Mac/Windows PC and control it via MOCO Feature in DSLRDASHBOARD?
regards
flow
Re: NMX Controller + QDSLRDASHBOARD via Ethernet
Posted: 27 Apr 2016, 06:03
No, there is no ethernet port on the NMX.
You can connect with USB to your PC and control from qDslrDashboard (USB serial communication)
or you can control with Bluetooth.
Posted: 27 Apr 2016, 10:10
by flow85
Ok, but will it work whith usb to ethernet adapter on both sides?
Posted: 27 Apr 2016, 10:28
No it will not work.
