Black screen. No live image.
xabierblanch
Post by xabierblanch »
I downloaded the last version dslrdashboard and after some problems with the Open gl 2.0 that I finally fixed (thanks to other forum topics) now, when I start the aplication I conect with my cam (D7200) but I don't see the live image on the screen. I see all the buttons, I can configure everything and choose diferent options but in all cases the main screen (when normally I see the live images) is black.
I know that it's a PC problem, because I tried in others computers succesfully, but I want to know if someone had similar experiences and found a solution.
Firstly, I had the problem with the OpenGL 2.0 that I fix downloading the three .dll that are in this forum. Can be related? I use Win 10, 64 bits, and a Intel HD graphics 3000.
Thanks!
Xabier
Re: Black screen. No live image.
xabierblanch
Thanks for all, I have copied the three .dll and din't try one per one. Putting only the last .dll i solve the problem.
Now the problem is how I can conect the D7200 with my Android phone. It's possible with the wifi built in cam?
I don't know what I'm doing wrong,
You can use the D7200 built in wireless.
Enable the D7200 wireless.
Connect/pair your Android device wireless to the D7200 wireless.
Start qDslrDashboard and press the 'Nikon wireless' button
Easy Mark
Post by Easy Mark »
I don't know if this helps, but I need to put my D7000 into S mode to get the live image to show up.
It won't show up if in CH or CL or Remote or Mirror Up or any of the other shooting modes.
I hope this helps and sorry if it doesn't.
Got D7000 and LV works with any shutter mode selected.
Easy Mark
Post by Easy Mark »
On my camera, it doesn't (as far as I can tell). Only in S (single frame) shutter mode.
Otherwise I just get a black screen. (sane as when qdd is in camera mode instead of host mode).
Than there is something wrong with your camera.
Checked again D7k, D5100, D5200, D610 - LV turns on in every shutter mode exept Mirror lockup (Mup)
plemingfarm
Post by plemingfarm »
Having exactly the same problem of black screen in LV with a D7000.
Camera is ok as can use with qdslrdashboard on android tablet ok.
I also had open gl problems which sorted with the three dll download after windows10 update.
Any advice welcome.
