openwrt trunk compile error
jiangxi
Post by jiangxi »
help! I think at openwrt trunk compile DslrDashboardServer, errors,
/home/jx/openwrt/staging_dir/toolchain-mipsel_24kec+dsp_gcc-5.3.0_musl-1.1.14/mipsel-openwrt-linux-musl/bin/../../../toolchain-mipsel_24kec+dsp_gcc-5.3. 0_musl-1.1.14 / lib / libgcc_s.so.1: error adding symbols: DSO missing from command line
But he was able in the 15.05 version through, there is your source on github is 0.2 - 12, ask where to download the source code to 0.2-14 it?
Re: openwrt trunk compile error
This is the actual version: https://github.com/hubaiz/DslrDashboardServer
jiangxi wrote:libgcc_s.so.1: error adding symbols: DSO missing from command line
Try searching for the error that you got
