TL-MR11U conection trouble
shotframers
I have a TL-MR11U and installed open wrt, then I tried to update to the latest firmware via WIFI to openwrt-ar71xx-generic-tl-mr11u-v2-squashfs-factory.bin. Now I can not acces the webinterface anymore. If i plug in the ethernet cable it gets an IP 192.168.1.139 and default gataway 192.168.1.1 but the webinterface is not connecting. Does anyone has an idea?
shotframers
Re: TL-MR11U conection trouble
So I managed to flash a diffrent firmware via SCP and Telnet. I am now at:
openwrt-15.05.1-ar71xx-generic-tl-mr11u-v2-squashfs-factory.bin
and installed the following ipk:
libpthread_0.9.33.2-1_ar71xx.ipk
ddserver_0.2-13_ar71xx.ipk
librt_0.9.33.2-1_ar71xx.ipk
libusb-1.0_1.0.9-1_ar71xx.ipk
uclibcxx_0.2.4-1_ar71xx.ipk
Then I connect the camera and the 3G light goeas on. After that I connect my phone to the tp link and started the app. I have now acces to the webinterface but not to the camera. what am i missing?
First check if ddserver is running, than check router log if camera is recognized.
It should show that a USB device was connected, and what device.
shotframers
DDserver is runing
If I plug in the camera, the following upears:
[ 2437.060000] usb 1-1: new full-speed USB device number 16 using ehci-platform
If I restart it manualy, this appears:
Sat May 28 09:51:00 2016 user.info syslog: DslrDashboardServer starting
Sat May 28 09:51:00 2016 user.info syslog: Starting socket server on port 4757
Sat May 28 09:51:00 2016 user.err syslog: ERROR on binding
edit/
now I can see this:
[ 2519.500000] usb 1-1: device not accepting address 19, error -145
[ 2519.500000] usb usb1-port1: unable to enumerate USB device
edit/
now I can see this:
shotframers
now I flashed ddserver_openwrt-tl-mr3040-v2-squashfs-sysupgrade_0.13.bin
And got this log: I tried with hub and without. With hub the led turns on, without nothing happens
Jun 1 20:54:04 OpenWrt kern.info kernel: [ 1415.310000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Jun 1 20:54:04 OpenWrt kern.info kernel: [ 1415.460000] hub 1-1:1.0: USB hub found
Jun 1 20:54:04 OpenWrt kern.info kernel: [ 1415.470000] hub 1-1:1.0: 4 ports detected
Jun 1 20:54:04 OpenWrt kern.info kernel: [ 1415.750000] usb 1-1.4: new high-speed USB device number 3 using ehci-platform
Jun 1 20:54:27 OpenWrt kern.info kernel: [ 1438.310000] usb 1-1.1: new high-speed USB device number 4 using ehci-platform
Jun 1 20:55:30 OpenWrt kern.info kernel: [ 1501.300000] usb 1-1.1: USB disconnect, device number 4
Jun 1 20:55:36 OpenWrt kern.info kernel: [ 1507.900000] usb 1-1: USB disconnect, device number 2
Jun 1 20:55:36 OpenWrt kern.info kernel: [ 1507.900000] usb 1-1.4: USB disconnect, device number 3
Jun 1 20:55:47 OpenWrt kern.info kernel: [ 1518.530000] usb 1-1: new full-speed USB device number 5 using ehci-platform
Jun 1 20:55:47 OpenWrt kern.err kernel: [ 1518.750000] usb 1-1: device descriptor read/64, error -71
Jun 1 20:55:47 OpenWrt kern.err kernel: [ 1519.070000] usb 1-1: device descriptor read/64, error -71
Jun 1 20:55:48 OpenWrt kern.info kernel: [ 1519.300000] usb 1-1: new full-speed USB device number 6 using ehci-platform
Jun 1 20:55:48 OpenWrt kern.err kernel: [ 1519.520000] usb 1-1: device descriptor read/64, error -71
Jun 1 20:55:48 OpenWrt kern.err kernel: [ 1519.840000] usb 1-1: device descriptor read/64, error -71
Jun 1 20:55:48 OpenWrt kern.info kernel: [ 1520.070000] usb 1-1: new full-speed USB device number 7 using ehci-platform
Jun 1 20:55:49 OpenWrt kern.err kernel: [ 1520.550000] usb 1-1: device not accepting address 7, error -71
Jun 1 20:55:49 OpenWrt kern.info kernel: [ 1520.670000] usb 1-1: new full-speed USB device number 8 using ehci-platform
Jun 1 20:55:49 OpenWrt kern.err kernel: [ 1521.150000] usb 1-1: device not accepting address 8, error -71
Jun 1 20:55:49 OpenWrt kern.err kernel: [ 1521.150000] hub 1-0:1.0: unable to enumerate USB device on port 1
Can anyone help me with this issue?
shotframers
I am still facing this problem. Does anyone have a solution? I am on ddserver_openwrt-tl-mr3040-v2-squashfs-sysupgrade_0.13.bin.
Well, it's no hard to find out why it doesn't work... MR11U is not MR3040 so why have you flashed MR3040 FW ??
shotframers
because MR11U was not working and no one was willing to help. BTW the error is still the same:
