Unable to start dslrDashboard
KönigderPimpfe
I'm unable to start dslrDashboard under Linux Mint Isadora. I try the x86 V.3.5.1. and the x64 V.3.5.1.
I click at the script and nothing is happen.
So what can I do to fix this issue???
KönigderPimpfe
KönigderPimpfe
Re: Unable to start dslrDashboard
Unpack the qDslrDashboard archive (tar -xzvf qDslrDashboard.tar.gz )
and then start with
./qDslrDashbaord.sh
and then start with
./qDslrDashbaord.sh
KönigderPimpfe
Then this came:hubaiz wrote:Unpack the qDslrDashboard archive (tar -xzvf qDslrDashboard.tar.gz )
and then start with
./qDslrDashbaord.sh
home@home-laptop ~/Downloads/qDslrDashboard_V3.5.1_Linux_x86 $ /home/home/Downloads/qDslrDashboard_V3.5.1_Linux_x86/./qDslrDashboard: error while loading shared libraries: libjpeg.so.8: cannot open shared object file: No such file or directory
KönigderPimpfe
With the x64 this came:
But a window is not opening.
home@home-laptop ~/Downloads/qDslrDashboard_V3.5.1_Linux_x64 $ ./qDslrDashboard.sh: Zeile 26: /home/home/Downloads/qDslrDashboard_V3.5.1_Linux_x64/./qDslrDashboard: Kann die Datei nicht ausführen.
./qDslrDashboard.sh: Zeile 26: /home/home/Downloads/qDslrDashboard_V3.5.1_Linux_x64/./qDslrDashboard: ErfolgRe: Unable to start dslrDashboard
Do you have an x86 or x64 system? You need to use the one that matches your system.
You could check with
or
also be sure that you preserve the archive folder structure and that you unpack all the files
uname -mCode: Select all
getconf LONG_BIT-
KönigderPimpfe
home@home-laptop ~ $ uname -m
i686
Ok, you need to use the x86 version.
You should install the libjpeg package.
KönigderPimpfe
I install libjpeg with:
But the same issue is coming.
sudo apt-get install libjpeg-
KönigderPimpfe
What can i do to fix the problem?
