OSX V0.2.OSX Crash
strikermed
OSX V0.2.OSX Crash
Post by strikermed »
The latest version is less stable than version 1.6. I continuously get crashes when attached to my Canon 60D via USB 2.0. I have a Mac Book Pro with 8gb ram, 2.6 intel i5. It will get to around 60 images at the max and then crash. I get the same issue many times on start up. I'm allowing for more than 2 seconds for jpeg transfer, and camera buffer, but the app still fails. Is there any way I can download previous versions to use? I can't do anything with this version.
Re: OSX V0.2.OSX Crash
Will see to make you a test version that has some fixes regarding Canon DSLR.
You need at least 2-3s with the smallest JPEGs and really fast SD card.
With bigger JPEGs it takes much more time. Tested by me minimum times needed to be set with internal time interval and image preview:
Nikon D7000 with SanDisk Extreme Pro, full size JPEG with highest quality - 3-4s
Nikon D5200 - 5-6s
Nikon D610 - 4-6s
Canon 60D - 4-6s
Canon 650D - 6-9s (this one is really slow with SD operations).
