Problems Windows 10 X64, qDSLRDashboard V3.5.1 on TL-MR3040 V1 and Nikon D90
kwalter
Post by kwalter »
Have problems with the qDSLRDashboard version 3.5.1 on Windows 10 x64.
When I connect my camera Nikon D90 via the TL-MR3040 V1 in LV mode, everything works without problems.
But if I take a picture, the picture is OK, then nothing works no AF etc..
Am I doing something wrong?
Can you please help me?
Best regards
kwalter
Re: Problems Windows 10 X64, qDSLRDashboard V3.5.1 on TL-MR3040 V1 and Nikon D90
Please try this newer build: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
You will need to use all the files from this archive as this is a newer build. You will also probably need to execute again the vcredist_x64 installer.
kwalter
Post by kwalter »
The vcredist_x64 re-installed, but after the program call and the connection to the server on the IP address 192.168.1.1 comes the following error message:
qDSLRDashboard V3.5.2.jpg (132.05 KiB) Viewed 11691 times
what is wrong?
Can you please give me the version for Windows 10 X86?
The program is supposed to run when it works on a tablet running Windows 10 X86.
Best regards
kwalter
I can but not right now, will try tomorrow.
kwalter
Post by kwalter »
Wait now for more than a month, unfortunately nothing has happened.
Please, can you give me the download link for the qDslrDashboard_V3.5.2_Windows_x86?
Best regards
kwalter
Sorry for delay, here is the x86 build: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
