Cannot Connect- wired
Lars_plus
Post by Lars_plus »
I can't get my Nikon D600 to connect to windows install DD. I'm using the supplied USB cable, and have installed the driver per DD website instructions. I've also tested the connection with Nikon software as well as Helicon Remote, both connect and function properly, so it seems like the driver and cable are both fine. My Windows machine is running Windows 8, but its 32-bit, so I installed the x86 version of DD. Should this work, or is this the problem? Any clues?
thanks!
Lars.
Re: Cannot Connect- wired
Did you install the WinUSB driver as described here: http://dslrdashboard.info/windows-insta ... sb-driver/
