d5500 crash after firmware upgrade
jcdnxs
Post by jcdnxs »
After upgrading the firmware of my Nikon D5500 from version 1.0 to version 1.01, i can never use qdslrdashboard again. The application opens and then closes with error.
Is there a solution to this? Does anyone have a solution or firmware 1. to downgrade?
Thank you for your help
Re: d5500 crash after firmware upgrade
On what device do you use qDslrDashboard?
What qDslrDashboard version do you use?
How do you connect the D5500?
jcdnxs
Post by jcdnxs »
I am using the version V0.3.4.2 installed on a sony Xperia Z5 android smartphone. Both WI-FI and USB connection close when trying to connect giving the following error message: "We regret the qdslrdashboard was interrupted"
I'm afraid the V0.3.4.2 will not work with updated D5500, Nikon changed one property that causes the crash and it was fixed in the V3.5.
jcdnxs
Post by jcdnxs »
Are you sure? If i upgrade qdslrdashboard to v0.3.5 i solve the problem?
jcdnxs
Post by jcdnxs »
Do you mean APP android arm V3.5.2?
Yes
jcdnxs
Post by jcdnxs »
Thanks it worked!
Thanks a lot
Do you already know that it is possible to record video in NIKON D3X00 with dslrdashboard using a simple bluethoot command of a selfie stick by sending the command "ENTER"?
Don't know about this.
jcdnxs
Post by jcdnxs »
and ALT RIGT command to capture a photo. Its wonderful.
DSLRDASHBOARD IT'S A FABULOUS PROGRAM AND IT'S WORTH THE MONEY IT COSTS. Thank you for your work.
