cannot stop bracketing with sony A7R
3dworks
Post by 3dworks »
if i start a custom bracketing session, the 'capture in progress' information will appear, but never disappear again. i also cannot stop the bracketing in any way. version 3.5.2 on iOS 10.2.1 connected to Sony A7R with firmware 3.20.
cheers
markus
Markus Gröteke / architectureshooting.com
Re: cannot stop bracketing with sony A7R
Do you use the latest 'Smart remote control' from Playmemories ( https://www.playmemoriescameraapps.com/ ... _00-F00002) ?
What setting did you use? Maybe a screen capture ?
jetswing
Post by jetswing »
I experience the same issue. Basically the bracketing session hangs. The camera shows "capture in progress" but you can tell the camera is not taking a shot and you can see the liveview feed on the LCD. The only way to reset is you close the app and restart.The same error occurs when the shutter speed exceeds 30 seconds.
