qDslrDashboard: error while loading shared libraries: libpulse-mainloop-glib.so.0: cannot open shared object file: No such file or directory.
Thanks.
qDslrDashboard_V3.5.3_RPI Cannot run in my raspberry pi 3b
Re: qDslrDashboard_V3.5.3_RPI Cannot run in my raspberry pi 3b
I guess this should fix this library
sudo apt-get install libpulse-mainloop-glib0Re: qDslrDashboard_V3.5.3_RPI Cannot run in my raspberry pi 3b
Thanks.The above problem has been resolved, but the following error occurred during operation:
This application failed to start because it could not find or load the Qt platform plugin "eglfs"
in "/home/pi/qDslrDashboard_V3.5.3_RPI/./Qt_Libraries/plugins/platforms".
Available platform plugins are: eglfs (from /home/pi/qDslrDashboard_V3.5.3_RPI/./Qt_Libraries/plugins/platforms), linuxfb (from /home/pi/qDslrDashboard_V3.5.3_RPI/./Qt_Libraries/plugins/platforms), minimal (from /home/pi/qDslrDashboard_V3.5.3_RPI/./Qt_Libraries/plugins/platforms), minimalegl (from /home/pi/qDslrDashboard_V3.5.3_RPI/./Qt_Libraries/plugins/platforms), offscreen (from /home/pi/qDslrDashboard_V3.5.3_RPI/./Qt_Libraries/plugins/platforms), vnc (from /home/pi/qDslrDashboard_V3.5.3_RPI/./Qt_Libraries/plugins/platforms), xcb (from /home/pi/qDslrDashboard_V3.5.3_RPI/./Qt_Libraries/plugins/platforms), eglfs, linuxfb, minimal, minimalegl, offscreen, vnc.
Reinstalling the application may fix this problem.
THANKS!
THANKS!
Did you set the graphics memory to 512 with raspi-config?
Eventually check with ldd libqeglfs.so if there are some missing dependencies
In accordance with your recommendation, qDslrDashboard_V3.5.3_RPI has been running properly on my device!
thanks a lot of!
thanks a lot of!
I restart this post beacause i'am in the same situation.
I do all the post say except this because i dont understood : "Eventually check with ldd libqeglfs.so if there are some missing dependencies"
What do you mean exactly for check this ?
i terminal command for upgrade ? Have you this please ? (i dont find it)
Thanks a lot
Damien
Thanks a lot
Damien
It means you into the folder where the libqeglfs.so librarie is and there you execute the 'ldd libqeglfs.so' command and it will list the library dependencies for it.
OK thanks, i look that.
Hy,
I ran in to the same issue with the missing "lib pulse" and installed it as discribed from hubaiz,
but now I get the following error
any ideas how to fix that ?
and yes I set the GPU memory to 512 already
Unable to query physical screen size, defaulting to 100 dpi.
PulseAudioService: pa_context_connect() failed
qml: windowRoot completed
qml: manager focus
qml: managerOverlayLoader active focus changed true
qml: manager overlay got focus true
qml: button active focus changed true index 0
qml: displayScreen DeviceScreen.qml
qml: on device buttons changed null
qml: getTime 0
qml: screenModel DeviceScreen(0xf84d08) devBtn null
qml: get osd source qml
qml: getTime 0
qml: DeviceScreen completed
qml: ScreenBase completed DeviceScreen(0xf84d08)
qml: error:
glGetError 0x500
qml: Timer triggered
grateful for any suggestions.
Tax
qml: manager focus
qml: getTime 0
qml: getTime 0
qml: error:
glGetError 0x500
Tax
according this it is running? Is your RPI connected to a HDMI monitor? How do you start qDD, from a shell?
edit: see at the end there is an OpenGL error at the end, did you start it from a shell or maybe a ssh login?
