5d MarkIII, tp-link 3040, ios ddserver not found
Posted: 05 Apr 2017, 12:21
by marianog
Hello
Basically this sums everything 5d MarkIII, tp-link 3040, ios ddserver not found.
I install the update in the tp link, and did the openWrt.
I see and can connect wifi on the iphone and ipad to ddserver, but in the moment I try to connect with the dslrdashboard app it says
DDserver not found, connecting to IP: 192.168.1.1
List connected DSLR at IP:192.168.1.1
I tried almost everything and still saying the same.
Any tip?
M
Re: 5d MarkIII, tp-link 3040, ios ddserver not found
Posted: 05 Apr 2017, 12:22
Posted: 06 Apr 2017, 22:40
by marianog
Thanks for your help.
I went through it but I don't have those code lines
instead I have this
Sep 8 15:44:22 OpenWrt user.info sysinit: Starting DslrDashboardServer (ddserver)
Sep 8 15:44:22 OpenWrt user.info sysinit: Saving PID 938 to /var/run/ddserver.pid
Sep 8 15:44:22 OpenWrt user.info sysinit: DslrDashboard server started
Sep 8 15:44:22 OpenWrt user.info syslog: DslrDashboardServer starting
Sep 8 15:44:22 OpenWrt user.info syslog: Starting socket server on port 4757
Sep 8 15:44:22 OpenWrt user.info syslog: Awaiting client connection
Sep 8 15:44:22 OpenWrt user.info syslog: Starting UDP listener
Sep 8 15:44:22 OpenWrt user.info syslog: join multicast group: 224.1.2.3
Sep 8 15:44:41 OpenWrt kern.info kernel: [ 49.410000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Sep 8 15:44:52 OpenWrt kern.err kernel: [ 59.950000] usb 1-1: device not accepting address 2, error -145
Sep 8 15:44:52 OpenWrt kern.info kernel: [ 60.070000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Sep 8 15:45:40 OpenWrt kern.info kernel: [ 108.360000] usb 1-1: USB disconnect, device number 3
Sep 8 15:46:15 OpenWrt daemon.info hostapd: wlan0: STA 9c:04:eb:92:ca:49 IEEE 802.11: authenticated
Sep 8 15:46:15 OpenWrt daemon.info hostapd: wlan0: STA 9c:04:eb:92:ca:49 IEEE 802.11: associated (aid 1)
Sep 8 15:46:18 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPDISCOVER(br-lan) 9c:04:eb:92:ca:49
Sep 8 15:46:18 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPOFFER(br-lan) 192.168.1.217 9c:04:eb:92:ca:49
Sep 8 15:46:19 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPREQUEST(br-lan) 192.168.1.217 9c:04:eb:92:ca:49
Sep 8 15:46:19 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPACK(br-lan) 192.168.1.217 9c:04:eb:92:ca:49 Marianos-iPad-2
Sep 8 15:48:43 OpenWrt kern.info kernel: [ 291.870000] usb 1-1: new high-speed USB device number 4 using ehci-platform
Sep 8 15:49:50 OpenWrt daemon.info hostapd: wlan0: STA f4:31:c3:2f:b6:36 IEEE 802.11: authenticated
Sep 8 15:49:50 OpenWrt daemon.info hostapd: wlan0: STA f4:31:c3:2f:b6:36 IEEE 802.11: associated (aid 2)
Sep 8 15:49:50 OpenWrt kern.info kernel: [ 358.880000] usb 1-1: USB disconnect, device number 4
Sep 8 15:49:53 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPDISCOVER(br-lan) f4:31:c3:2f:b6:36
Sep 8 15:49:53 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPOFFER(br-lan) 192.168.1.210 f4:31:c3:2f:b6:36
Sep 8 15:49:54 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPREQUEST(br-lan) 192.168.1.210 f4:31:c3:2f:b6:36
Sep 8 15:49:54 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPACK(br-lan) 192.168.1.210 f4:31:c3:2f:b6:36 MarianoiPhone6
Sep 8 15:51:05 OpenWrt daemon.info hostapd: wlan0: STA f4:31:c3:2f:b6:36 IEEE 802.11: disassociated
Sep 8 15:51:06 OpenWrt daemon.info hostapd: wlan0: STA f4:31:c3:2f:b6:36 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sep 8 15:52:13 OpenWrt user.info syslog: recv: 57
Sep 8 15:52:13 OpenWrt user.info syslog: Client multicast query DslrDashboardClient{9239b412-d642-4e1e-9cde-be7918a87ce9}
Sep 8 15:52:13 OpenWrt user.info syslog: Server message length: 57 msg: DslrDashboardServer{9239b412-d642-4e1e-9cde-be7918a87ce9}
Sep 8 15:52:15 OpenWrt user.info syslog: Incoming client connection
Sep 8 15:52:15 OpenWrt user.info syslog: Awaiting client connection
Sep 8 15:52:15 OpenWrt user.info syslog: USB Devices in
Sep 8 15:52:15 OpenWrt user.info syslog: Number of possible configurations: 1 Device Class: 9 VendorID: 7531, ProductID: 2
Sep 8 15:52:15 OpenWrt user.info syslog: Number of alternate settings:
Sep 8 15:52:15 OpenWrt user.info syslog: Interface class: 9 Interface number: 0 Number of endpoints: 1
Sep 8 15:52:15 OpenWrt user.info syslog: Imaging USB devices found: 0
Sep 8 15:52:15 OpenWrt user.err syslog: Error reading total packet size: 0
Sep 8 15:52:15 OpenWrt user.err syslog: Stoping client
Sep 8 15:52:17 OpenWrt user.info syslog: Closing USB device
Sep 8 15:52:29 OpenWrt daemon.info hostapd: wlan0: STA 9c:04:eb:92:ca:49 IEEE 802.11: disassociated
Sep 8 15:52:30 OpenWrt daemon.info hostapd: wlan0: STA 9c:04:eb:92:ca:49 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sep 8 15:58:18 OpenWrt daemon.info hostapd: wlan0: STA 04:1e:64:ec:ff:5c IEEE 802.11: authenticated
Sep 8 15:58:18 OpenWrt daemon.info hostapd: wlan0: STA 04:1e:64:ec:ff:5c IEEE 802.11: associated (aid 1)
Sep 8 15:58:18 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPREQUEST(br-lan) 10.0.0.37 04:1e:64:ec:ff:5c
Sep 8 15:58:18 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPNAK(br-lan) 10.0.0.37 04:1e:64:ec:ff:5c wrong network
Sep 8 15:58:21 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPDISCOVER(br-lan) 04:1e:64:ec:ff:5c
Sep 8 15:58:21 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPOFFER(br-lan) 192.168.1.192 04:1e:64:ec:ff:5c
Sep 8 15:58:22 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPREQUEST(br-lan) 192.168.1.192 04:1e:64:ec:ff:5c
Sep 8 15:58:22 OpenWrt daemon.info dnsmasq-dhcp[922]: DHCPACK(br-lan) 192.168.1.192 04:1e:64:ec:ff:5c MarianoGsiMac5
How can I fix it?
Thanks a lot in advance for your help
Posted: 07 Apr 2017, 08:42
Is the camera connected to the MR3040 full size USB port without using any adapter?
Do you have another USB cable (a short one) ?
Posted: 07 Apr 2017, 20:58
by marianog
Hello
Yes it's connected with a short usb cord to the Tp Link and no adapters on any side of the cable
Posted: 14 Apr 2017, 15:16
by marianog
Hello
I've seen that I'm not the only one with the same problem, and Nikon users have the same issue.
Did anyone find a solution for us?
M
Posted: 15 Apr 2017, 07:14
The problem is that the MR3040 is not recognizing the camera. It can be that the USB cable is to long or poor quality.
So using another cable for testing is a good idea.
You can also try and reflash the MR3040 with the sysupgrade image using the instructions from here:
https://dslrdashboard.info/tp-link-mr30 ... e-upgrade/
