Nikon D810 crashes when starting Liveview
Mhueller
Post by Mhueller »
I own a Nikon D5200 and a D810. (Upgraded from a D800).
With the D800 and D5200 everything worked fine. On USB connection and on WIFI with TP-Link Router.
Now with the D810 QDSLRDASHBOARD always crashes when starting Liveview.
I use a Asus Nexus 7 Tab and a Samsung Galaxy S4.
Any Idea whats going wrong.
Regards
Re: Nikon D810 crashes when starting Liveview
Can you eventually run a Windows or OSX version?
Mhueller
Post by Mhueller »
I just installed the Win X64 Version.
Could not get a connection to my D810. With the D5200 it works fine.
Tryed USB and WIFI connection.
Regards
You need to install the WinUSB driver for the D810 as instructed here: https://dslrdashboard.info/windows-inst ... sb-driver/
Here is the debug version: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
Just unpack the archive into the qDslrDashboard folder and start with the qDslrDashboard_debug.exe
On each start it will create a new qdd_<date_time>.log file in your 'Documents' folder. Please send it to the support email.
