Tplink TL-mr3040 discontinued
Tplink TL-mr3040 discontinued Get them while you can prices have doubled on the stock the shops have and they said at Tplink now discontinued !
Re: Tplink TL-mr3040 discontinued
What do we use now ?
You can use any OpenWRT-compatible router.
https://wiki.openwrt.org/toh/start
Well we want to use a router with a rechargeable battery so can you narrow it down to a list of 5 maybe !
I think you may like this one.
https://www.aliexpress.com/store/produc ... 0.0.zpRiFL
6000Mah rechargeable Li-battery Inside. qDslrDashboard compatible.
russellsnr
Not 100% sure if this will work with QDSLRD but does with DSLRController. Maybr hubaiz can confirm?
and only US $15.49
Approximately £11.81
http://www.ebay.co.uk/itm/NEXX-WT3020F- ... 1438.l2649
and only US $15.49
Hi, I bought the rooter proposed in this post with the aliexpress link.
I am totally satisfied. it will replace my tplink 3020 which needs external alimentation.
I have now 1 Dslr with a 3040 tplink and the second one with this new rooter and the autonomy is better.
Dominique
Dominique
