I have flashed my MR-3040 with openwrt and using qdlsrdashboard can connect to my Nikon D300 via the hard wire network connection but I am unable to get it to work with the wifi. Any ideas/suggestions?
bill
New to Forum - With a Q
Re: New to Forum - With a Q
Turn on the MR3040 and connect your PC with it (wireless or wired)
Open your browser and navigate to http://192.168.1.1
Do you get the OpenWrt web administration page?
If yes then navigate to System->Software and check you have there the ddserver package (should be V0.2-13)
Connect your DSLR to MR3040 with USB and turn it on.
The in OpenWrt web interface navigate to Status->System Log
You should have there something like this:
Do you have it?
May 1 07:49:18 Arduino kern.info kernel: [349129.920000] usb 1-1.1.4.4: new high-speed USB device number 48 using ehci-platform
May 1 07:49:18 Arduino kern.info kernel: [349130.030000] usb 1-1.1.4.4: New USB device found, idVendor=04b0, idProduct=0430
May 1 07:49:18 Arduino kern.info kernel: [349130.030000] usb 1-1.1.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 1 07:49:18 Arduino kern.info kernel: [349130.030000] usb 1-1.1.4.4: Product: NIKON DSC D7100
May 1 07:49:18 Arduino kern.info kernel: [349130.040000] usb 1-1.1.4.4: Manufacturer: NIKON
May 1 07:49:18 Arduino kern.info kernel: [349130.040000] usb 1-1.1.4.4: SerialNumber: 4302375Re: New to Forum - With a Q
Not sure how much you want. Here's what it looks like before I use qdslrdashboard:
Fri Oct 18 08:18:12 2013 kern.emerg - init complete -
Fri Oct 18 08:18:13 2013 kern.info kernel: [ 22.660000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Fri Oct 18 08:18:13 2013 kern.info kernel: [ 22.680000] device wlan0 entered promiscuous mode
Fri Oct 18 08:18:13 2013 kern.info kernel: [ 22.690000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Fri Oct 18 08:18:13 2013 kern.info kernel: [ 23.050000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Fri Oct 18 08:18:13 2013 kern.info kernel: [ 23.060000] br-lan: port 2(wlan0) entered forwarding state
Fri Oct 18 08:18:15 2013 kern.info kernel: [ 25.060000] br-lan: port 2(wlan0) entered forwarding state
Fri Oct 18 08:18:16 2013 daemon.notice netifd: WiFi (883): udhcpc (v1.19.4) started
Fri Oct 18 08:18:16 2013 daemon.notice netifd: WiFi (883): Sending discover...
Fri Oct 18 08:18:19 2013 daemon.notice netifd: WiFi (883): Sending discover...
Fri Oct 18 08:18:22 2013 daemon.notice netifd: WiFi (883): Sending discover...
Fri Oct 18 08:18:23 2013 daemon.info dnsmasq[735]: read /etc/hosts - 1 addresses
Fri Oct 18 08:18:23 2013 daemon.info dnsmasq[735]: read /tmp/hosts/6relayd - 1 addresses
Here is the entire log entry since boot up this AM:
Fri Oct 18 08:18:00 2013 kern.emerg Fri Oct 18 08:18:00 UTC 2013
Fri Oct 18 08:18:00 2013 user.emerg syslog: kmodloader: loading kernel modules from /etc/modules.d/**
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 9.900000] NET: Registered protocol family 10
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 9.920000] nf_conntrack version 0.5.0 (454 buckets, 1816 max)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 9.930000] ip6_tables: (C) 2000-2006 Netfilter Core Team
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 9.960000] Loading modules backported from Linux version master-2013-06-27-0-gdcfa6d5
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 9.970000] Backport generated by backports.git backports-20130617-4-ge3220f5
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 9.980000] ip_tables: (C) 2000-2006 Netfilter Core Team
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.030000] xt_time: kernel timezone is -0000
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.060000] cfg80211: Calling CRDA to update world regulatory domain
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.060000] cfg80211: World regulatory domain updated:
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.070000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.070000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.080000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.090000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.100000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.100000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.190000] PPP generic driver version 2.4.2
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.190000] NET: Registered protocol family 24
Fri Oct 18 08:18:00 2013 kern.debug kernel: [ 10.270000] ath: EEPROM regdomain: 0x0
Fri Oct 18 08:18:00 2013 kern.debug kernel: [ 10.270000] ath: EEPROM indicates default country code should be used
Fri Oct 18 08:18:00 2013 kern.debug kernel: [ 10.270000] ath: doing EEPROM country->regdmn map search
Fri Oct 18 08:18:00 2013 kern.debug kernel: [ 10.270000] ath: country maps to regdmn code: 0x3a
Fri Oct 18 08:18:00 2013 kern.debug kernel: [ 10.270000] ath: Country alpha2 being used: US
Fri Oct 18 08:18:00 2013 kern.debug kernel: [ 10.270000] ath: Regpair used: 0x3a
Fri Oct 18 08:18:00 2013 kern.debug kernel: [ 10.270000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.290000] cfg80211: Calling CRDA for country: US
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.300000] cfg80211: Regulatory domain changed to country: US
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.300000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.310000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.320000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.320000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.330000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.340000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.350000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
Fri Oct 18 08:18:00 2013 kern.info kernel: [ 10.370000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
Fri Oct 18 08:18:00 2013 user.info syslog: ran 44 iterations
Fri Oct 18 08:18:00 2013 kern.emerg kmod: ran 44 iterations
Fri Oct 18 08:18:05 2013 authpriv.info dropbear[565]: Not backgrounding
Fri Oct 18 08:18:06 2013 kern.info kernel: [ 16.030000] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Fri Oct 18 08:18:06 2013 kern.info kernel: [ 16.030000] device eth0 entered promiscuous mode
Fri Oct 18 08:18:06 2013 daemon.notice netifd: Interface 'lan' is now up
Fri Oct 18 08:18:06 2013 kern.info kernel: [ 16.050000] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Fri Oct 18 08:18:06 2013 daemon.notice netifd: Interface 'loopback' is now up
Fri Oct 18 08:18:06 2013 kern.info kernel: [ 16.250000] eth0: link up (100Mbps/Full duplex)
Fri Oct 18 08:18:06 2013 kern.info kernel: [ 16.250000] br-lan: port 1(eth0) entered forwarding state
Fri Oct 18 08:18:06 2013 kern.info kernel: [ 16.260000] br-lan: port 1(eth0) entered forwarding state
Fri Oct 18 08:18:06 2013 kern.info kernel: [ 16.260000] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Fri Oct 18 08:18:06 2013 kern.info kernel: [ 16.280000] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Fri Oct 18 08:18:07 2013 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Fri Oct 18 08:18:08 2013 daemon.err 6relayd[658]: Unable to open interface wan6 (No such device)
Fri Oct 18 08:18:08 2013 kern.info kernel: [ 18.260000] br-lan: port 1(eth0) entered forwarding state
Fri Oct 18 08:18:08 2013 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Fri Oct 18 08:18:09 2013 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Fri Oct 18 08:18:09 2013 user.notice dnsmasq: found already running DHCP-server on interface 'br-lan' refusing to start, use 'option force 1' to override
Fri Oct 18 08:18:09 2013 daemon.info dnsmasq[735]: started, version 2.66 cachesize 150
Fri Oct 18 08:18:09 2013 daemon.info dnsmasq[735]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Fri Oct 18 08:18:09 2013 daemon.info dnsmasq[735]: using local addresses only for domain lan
Fri Oct 18 08:18:09 2013 daemon.warn dnsmasq[735]: no servers found in /tmp/resolv.conf.auto, will retry
Fri Oct 18 08:18:09 2013 daemon.info dnsmasq[735]: read /etc/hosts - 1 addresses
Fri Oct 18 08:18:09 2013 kern.emerg grep: /proc/658/cmdline: No such file or directory
Fri Oct 18 08:18:11 2013 daemon.info dnsmasq[735]: read /etc/hosts - 1 addresses
Fri Oct 18 08:18:11 2013 daemon.info dnsmasq[735]: read /tmp/hosts/6relayd - 0 addresses
Fri Oct 18 08:18:11 2013 kern.emerg setting up led USB
Fri Oct 18 08:18:11 2013 kern.emerg setting up led WLAN
Fri Oct 18 08:18:11 2013 kern.emerg setting up led LAN
Fri Oct 18 08:18:11 2013 kern.emerg start
Fri Oct 18 08:18:11 2013 kern.emerg Saving PID 835 to /var/run/DSLRController.pid
Fri Oct 18 08:18:11 2013 kern.emerg Ok
Fri Oct 18 08:19:56 2013 daemon.info hostapd: wlan0: STA fc:c2
f6:61:31 IEEE 802.11: authenticated
f6:61:31 IEEE 802.11: associated (aid 1)
f6:61:31 WPA: pairwise key handshake completed (RSN)
Fri Oct 18 08:20:28 2013 daemon.info hostapd: wlan0: STA fc:c2
f6:61:31 IEEE 802.11: disassociated
Fri Oct 18 08:20:29 2013 daemon.info hostapd: wlan0: STA fc:c2
Fri Oct 18 08:21:02 2013 daemon.info hostapd: wlan0: STA fc:c2
Fri Oct 18 08:21:03 2013 daemon.info hostapd: wlan0: STA fc:c2
Fri Oct 18 08:21:35 2013 daemon.info hostapd: wlan0: STA fc:c2
Fri Oct 18 08:21:40 2013 daemon.info hostapd: wlan0: STA fc:c2
Seams you are using the wrong firmware.
The OpenWrt ddserver firmware is available here: http://dslrdashboard.info/downloads/
I downloaded the firmware image from the link you provided and re-flashed the router. Once re-connected the version shows up as:
Powered by LuCI 0.11 Branch (0.11+svn9951) OpenWrt Attitude Adjustment 12.09.1
Is that correct?
Is that correct?
OK, so using my tablet I can connected to the router with the Nikon D300 connected to both via USB. But that is via the network cable connected to my home network router. When I disconnected that cable I'd like to connect via wireless but I cannot. I can ssh into the MR3040 and see ddserver running, etc. Before I just start making changes tothe config do you have any ideas?
bill
bill
You should pair your tablet wireless with the MR3040 wireless and press the network button.
If it does not find the connected camera try and long press the 'Network' button and enter the router IP address (192.168.1.1 by default) and finally press the 'Connect' button.
Once I attempt pairing it goes into "obtaining ip address" and nothing happens. It seems the 192.168.1.1 address is assigned tothe ethernet interface and there is nothing assigned to the wifi interface.
br-lan Link encap:Ethernet HWaddr 30:B5:C2:4B:5D:16
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:107869 errors:0 dropped:24 overruns:0 frame:0
TX packets:175532 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:5976592 (5.6 MiB) TX bytes:249751192 (238.1 MiB)
eth0 Link encap:Ethernet HWaddr 30:B5:C2:4B:5D:16
RX packets:107861 errors:0 dropped:0 overruns:0 frame:0
TX packets:175516 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:7484628 (7.1 MiB) TX bytes:249750496 (238.1 MiB)
Interrupt:4
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:27858 errors:0 dropped:0 overruns:0 frame:0
TX packets:27858 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1894469 (1.8 MiB) TX bytes:1894469 (1.8 MiB)
wlan0 Link encap:Ethernet HWaddr 30:B5:C2:4B:5D:16
RX packets:11 errors:0 dropped:0 overruns:0 frame:0
TX packets:12033 errors:0 dropped:0 overruns:0 carrier:0
Interrupt:4
