qDSLRdashboard can not connect with TP-Link 3040
Dartgott
Post by Dartgott »
Hello Users
I have a big trouble with the Software qDSLRdashboard and the TP-Link 3040
I have install the Software and Firmware of the TP-LINK 3040 Router.
When i connected the Router with my iPad or iMac, i have not Problems.
When i started the App qDSLRdashboard and click on connection, i become the following information
Under the ip 192.168.1.1 i can log in and can see all of settings.
i can connect over WLan withe the Computer or iPad with the Router, but than....
Searching for DDServer
DDServer not found, connecting to IP: 192.168.1.1
List connected DSLR at IP 192.168.1.1
Error gettingDSLR list from IP: 192.168.1.1
What is the Problem?
Can you help me?
Hardware:
TP-LINK Portable 3G/4G Wireless N Router TL-MR3040
iPad Pro 4G / Cellular with qDSLRdashboard App
iMac 27“ with the Software qDSLRdashboard
Canon EOS 1200D
The Post "Checking the ddserver installation and USB connection" i have did it.
i did Firmware Update TP-LINK 3040MR
I did Firmware Update Camera
and now i have no idea what can i do at next
Here the System Log
Sep 8 18:12:04 OpenWrt syslog.info syslogd started: BusyBox v1.19.4
Sep 8 18:12:04 OpenWrt kern.notice kernel: klogd started: BusyBox v1.19.4 (2014-07-11 18:33:29 CEST)
Sep 8 18:12:04 OpenWrt kern.notice kernel: [ 0.000000] Linux version 3.3.8 (hubaiz@xandroid64) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Fri Jul 11 18:39:12 CEST 2014
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] MyLoader: sysp=fa89c804, boardp=69cd3b24, parts=31a09c82
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] bootconsole [early0] enabled
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] SoC: Atheros AR9330 rev 1
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Determined physical RAM map:
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] memory: 02000000 @ 00000000 (usable)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Zone PFN ranges:
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Normal 0x00000000 -> 0x00002000
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Movable zone start PFN for each node
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Early memory PFN ranges
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] 0: 0x00000000 -> 0x00002000
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] On node 0 totalpages: 8192
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 802d61e0, node_mem_map 81000000
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] Normal zone: 64 pages used for memmap
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] Normal zone: 8128 pages, LIFO batch:0
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Sep 8 18:12:04 OpenWrt kern.notice kernel: [ 0.000000] Kernel command line: board=TL-MR3040 console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Memory: 29116k/32768k available (2115k kernel code, 3652k reserved, 406k data, 208k init, 0k highmem)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] NR_IRQS:51
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.080000] pid_max: default: 32768 minimum: 301
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.080000] Mount-cache hash table entries: 512
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.090000] NET: Registered protocol family 16
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.100000] MIPS: machine is TP-LINK TL-MR3040
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.350000] bio: create slab <bio-0> at 0
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.360000] Switching to clocksource MIPS
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.360000] NET: Registered protocol family 2
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.370000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.370000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.370000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.380000] TCP: Hash tables configured (established 1024 bind 1024)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.390000] TCP reno registered
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.390000] UDP hash table entries: 256 (order: 0, 4096 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.400000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.400000] NET: Registered protocol family 1
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 9.450000] ath: country maps to regdmn code: 0x3a
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 9.450000] ath: Country alpha2 being used: US
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 9.450000] ath: Regpair used: 0x3a
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 9.450000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 9.460000] Registered led device: ath9k-phy0
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.460000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.470000] cfg80211: Calling CRDA for country: US
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.470000] cfg80211: Regulatory domain changed to country: US
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.470000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.480000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.490000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.500000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.510000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.510000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.520000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.570000] PPP generic driver version 2.4.2
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.820000] ip_tables: (C) 2000-2006 Netfilter Core Team
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.040000] NET: Registered protocol family 24
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.060000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.070000] ehci-platform ehci-platform: Generic Platform EHCI Controller
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.070000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.110000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.130000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.130000] hub 1-0:1.0: USB hub found
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.130000] hub 1-0:1.0: 1 port detected
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.160000] nf_conntrack version 0.5.0 (458 buckets, 1832 max)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.400000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Sep 8 18:12:06 OpenWrt daemon.notice netifd: Interface 'lan' is now up
Sep 8 18:12:06 OpenWrt kern.info kernel: [ 14.830000] device eth0 entered promiscuous mode
Sep 8 18:12:06 OpenWrt daemon.notice netifd: Interface 'loopback' is now up
Sep 8 18:12:07 OpenWrt user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.070000] cfg80211: Calling CRDA for country: DE
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.070000] cfg80211: Regulatory domain changed to country: DE
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.070000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.080000] cfg80211: (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 2000 mBm)
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.090000] cfg80211: (5150000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm)
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.100000] cfg80211: (5250000 KHz - 5350000 KHz @ 40000 KHz), (N/A, 2000 mBm)
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.100000] cfg80211: (5470000 KHz - 5725000 KHz @ 40000 KHz), (N/A, 2700 mBm)
Sep 8 18:12:13 OpenWrt kern.info kernel: [ 21.150000] device wlan0 entered promiscuous mode
Sep 8 18:12:13 OpenWrt kern.info kernel: [ 21.200000] br-lan: port 2(wlan0) entered forwarding state
Sep 8 18:12:15 OpenWrt kern.info kernel: [ 23.200000] br-lan: port 2(wlan0) entered forwarding state
Sep 8 18:12:16 OpenWrt authpriv.info dropbear[879]: Running in background
Sep 8 18:12:16 OpenWrt authpriv.warn dropbear[881]: Failed listening on '22': Error listening: Address already in use
Sep 8 18:12:16 OpenWrt authpriv.info dropbear[881]: Premature exit: No listening ports available.
Sep 8 18:12:18 OpenWrt auth.err sshd[889]: error: Bind to port 22 on 0.0.0.0 failed: Address already in use.
Sep 8 18:12:18 OpenWrt auth.crit sshd[889]: fatal: Cannot bind any address.
Sep 8 18:12:19 OpenWrt user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Sep 8 18:12:19 OpenWrt user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq[947]: started, version 2.66 cachesize 150
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq[947]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq-dhcp[947]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq[947]: using local addresses only for domain lan
Sep 8 18:12:23 OpenWrt daemon.warn dnsmasq[947]: no servers found in /tmp/resolv.conf.auto, will retry
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq[947]: read /etc/hosts - 1 addresses
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq-dhcp[947]: read /etc/ethers - 0 addresses
Sep 8 18:12:23 OpenWrt user.info sysinit: setting up led USB
Sep 8 18:12:23 OpenWrt user.info sysinit: setting up led WLAN
Sep 8 18:12:23 OpenWrt user.info sysinit: setting up led LAN
Sep 8 18:12:23 OpenWrt user.info sysinit: Starting DslrDashboardServer (ddserver)
Sep 8 18:12:23 OpenWrt user.info sysinit: Saving PID 963 to /var/run/ddserver.pid
Sep 8 18:12:23 OpenWrt user.info sysinit: DslrDashboard server started
Sep 8 18:12:23 OpenWrt user.info syslog: DslrDashboardServer starting
Sep 8 18:12:23 OpenWrt user.info syslog: Starting socket server on port 4757
Sep 8 18:12:23 OpenWrt user.info syslog: Awaiting client connection
Sep 8 18:12:23 OpenWrt user.info syslog: Starting UDP listener
Sep 8 18:12:23 OpenWrt user.info syslog: join multicast group: 224.1.2.3
Sep 8 18:12:23 OpenWrt user.err syslog: error in joining multicast group -1
Sep 8 18:12:35 OpenWrt kern.info kernel: [ 43.450000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Sep 8 18:12:35 OpenWrt kern.info kernel: [ 43.700000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Sep 8 18:12:36 OpenWrt kern.info kernel: [ 43.950000] usb 1-1: new high-speed USB device number 4 using ehci-platform
Sep 8 18:12:36 OpenWrt kern.err kernel: [ 44.370000] usb 1-1: device not accepting address 4, error -71
Sep 8 18:12:36 OpenWrt kern.info kernel: [ 44.490000] usb 1-1: new high-speed USB device number 5 using ehci-platform
Sep 8 18:12:37 OpenWrt kern.err kernel: [ 44.910000] usb 1-1: device not accepting address 5, error -71
Sep 8 18:12:37 OpenWrt kern.err kernel: [ 44.910000] hub 1-0:1.0: unable to enumerate USB device on port 1
Sep 8 18:12:49 OpenWrt daemon.info hostapd: wlan0: STA e4:ce:8f:64:4a:e5 IEEE 802.11: Station tried to associate before authentication (aid=-1 flags=0x0)
Sep 8 18:12:49 OpenWrt daemon.info hostapd: wlan0: STA e4:ce:8f:64:4a:e5 IEEE 802.11: authenticated
Sep 8 18:12:49 OpenWrt daemon.info hostapd: wlan0: STA e4:ce:8f:64:4a:e5 IEEE 802.11: associated (aid 1)
Sep 8 18:12:49 OpenWrt daemon.info dnsmasq-dhcp[947]: DHCPREQUEST(br-lan) 192.168.1.199 e4:ce:8f:64:4a:e5
Sep 8 18:12:49 OpenWrt daemon.info dnsmasq-dhcp[947]: DHCPACK(br-lan) 192.168.1.199 e4:ce:8f:64:4a:e5 Marios-iMac
Re: qDSLRdashboard can not connect with TP-Link 3040
It looks like router cannot establish USB connection with camera.
Try different usb cable, preferably the one that came with camera. I've found that some (if not most) Canon DLSRs need cables with longer mini usb plugs than standard.
Dartgott
Post by Dartgott »
GonzoG wrote: ↑20 Sep 2017, 21:53 It looks like router cannot establish USB connection with camera.
Hi
Thanks for your info.
I try 6 different USB Cable (2 new and 4 old cable) and a lot of different Canon EOS Camera.
No single camera was detected at the USP Port.
