connecting to Nikon D5
Morpheus92949
Post by Morpheus92949 »
Hello
Does the software qDslrDashboard support Nikon D5?
Greetings Martin
Re: connecting to Nikon D5
Yes, the D5 will work with qDslrDashboard.
Johanm
Post by Johanm »
How should setting be a n camera for it to work? Im not able to connect neither if i put it to hhtp mode or PC control mode or ftp mode. Im not able to change port number in the qDSLRDashboard program , connection property for nikon camera, ip address i was able to change.
What transfer method is qDSLRDashboard using? Something that is not standard since the portnunber value us 15xxx.
Connection to camera works because i can connect to http but now i need to Know correct setting and mode for the qDSLRDashboard to connect.
Thanks in advance.
It will work with USB connection.
Johanm
Post by Johanm »
That's not what i want when i bought a WiFi adapter...
