i will use the Software on a Raspberry, but when i will start then i get the following error:
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root' * failed to add service - already in use?
What does it mean?
Regards,
Raker87
Install on Raspberry
Re: Install on Raspberry
On what Raspberry Pi did you run it?
What Raspbian version did you use?
Did you follow the instructions here: viewtopic.php?f=6&t=2468
I have reinstall the raspberry.
But now i get another issue
sudo ./qDslrDashboard.sh
pi@raspberrypi:~/Downloads/qDslrDashboard_V3.5.5_RPI_Stretch $ QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
Unable to query physical screen size, defaulting to 100 dpi.
qt.qpa.input: X-less xkbcommon not available, not performing key mapping
qml: windowRoot completed
qml: manager focus
qml: managerOverlayLoader active focus changed true
qml: manager overlay got focus true
qml: button active focus changed true index 0
qml: displayScreen DeviceScreen.qml
qml: on device buttons changed null
qml: getTime 0
qml: screenModel DeviceScreen(0x1ff7748) devBtn null
qml: get osd source qml
qml: getTime 0
qml: DeviceScreen completed
qml: ScreenBase completed DeviceScreen(0x1ff7748)
qml: error:
glGetError 0x500
qml: Timer triggered
Do you know what the problem is?
qml: manager focus
qml: getTime 0
qml: getTime 0
qml: error:
glGetError 0x500
Raspberry Pi 3b
Stretch - newest Update
Raspberry Pi 3b
According the log you provided it did run as it should.
