I dont get it -rasbian stretch
Higlo
Post by Higlo »
Please I need some help to get it startet.
I did it the way discribed in the guide 3.5.5
The failure i get:
$ QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
libEGL warning: DRI2: failed to authenticate
Unable to query physical screen size, defaulting to 100 dpi.
qt.qpa.input: X-less xkbcommon not available, not performing key mapping
qml: windowRoot completed
EGL Error : Could not create the egl surface: error = 0x300b
My dslr was not connected at starting.
My system: raspberry pi3b+, 2018-03-13-raspbian-stretch, 5" waveshare touch lcd 800x480, esync touch pad keyboard
Thank you, very much
poke0s
Re: I dont get it -rasbian stretch
Post by poke0s »
hey.. I've got exactly the same problem. did apt-get update, apt-get dict-upgrade and pi-upgrade just like in the manual. got 3.5.7 on rasbian stretch
I documented here how to run it on RPI 3 and Raspbian Stretch:
https://dslrdashboard.info/phpBB3/viewt ... it=stretch
