Sony ILCE
speedster
Sony ILCE
Post by speedster »
Hello!
Sony A6000 connects via wifi and shows live view. As soon as I pick a button, Lv freezes and all buttons are frozen. Can't adjust settings, take an image, etc. Shutter, f/, and ISO pop up the sliders but changing a setting does not change the displayed values or the actual settings in the camera.
Am I missing something?
Can the Sony A6000 only connect via wifi and can not connect via USB?
When I attempt USB connection, qDslr says "Connecting to USB DSLR Sony ILCE-6000" and hangs there. At first qDslr would not try to connect so I ran Zadig so it now tries to connect. I normally connect to Imaging Edge via USB but Zadig messed up something and now other software does not recognize that the camera is connected via USB. I still have a few things to try to fix that situation but if you have a tip for that it would also be appreciated.
Thanks!
Re: Sony ILCE
For Sony cameras only wireless connection is possible. USB will not work for Sony cameras.
