no ISO ramping on holy grail
mysticalpics
Post by mysticalpics »
i got no iso ramping in holy grail.
tested on 2 different setups
both canon eos6d via wifi
qdsrldashboard both on android (smartphone and tablet)
shutter via other remote delay = 34s
sunset
shutterspeed up to 30s, but after that cam stays on iso 100.
max iso = 1600
no idea whats wrong, had the same issue yesterday
the cams stays in iso100
cam setup mode M
imagetransfer jpg M (1920x1080)
focusmode M
Re: no ISO ramping on holy grail
I would say that the 34s is not enough, try with 35s eventually 36s just to see if that works.
mysticalpics
ok thanks... ill try that tonight to 40s
first i thought so, but im wondering why shutterspeed ramping works and iso not. thought kind of misconfiguration, thats why i did the setup on another cam/smartphone.
mysticalpics
wuhuuuu..yessss... 40s solved the problem!
but 35s will work as well... thats my settings from earlier timelapses, which all worked fine...
thanks man... spent so much time to find the problem.
Kevinjjjack
Post by Kevinjjjack »
What do you mean 40s? I'm doing 7 second int on 6dmkii. Qdslr ramps the shutter speed, but won't ramp the iso (or aperture).
