QDslr Instructions?
Patrick_Seattle
QDslr Instructions?
Post by Patrick_Seattle »
Is there any kind of manual or instructions for qDslr Dashboard? I'm looking for info like: Does it still control the camera if you switch to a different app? Does it send the instructions to the camera or must the app and iPhone stay on and keep the qDslr app open? What happens if a phone call comes in when the app is running, will it abandon the current process?
I searched a while on the forums and could not find the above specific info.
Thanks,
Patrick
Re: QDslr Instructions?
On iOS it should be in front as the network connection will be cut by iOS if you put the application in background.
Same is true for the screen, there is a 'Keep screen on' option in qDD settings.
Patrick_Seattle
Thanks, I'll keep it on. I'm considering picking up an iPod Touch to dedicate to camera apps, do you see any reason it would not be ideal for your app?
