Install Issue(s)
AndyPost
Install Issue(s)
Post by AndyPost »
Hey Thrill Seekers,
Trying to install on Windows 7-64 bit.
If I try to install vcredist_x64.exe as I understand I must, I get a failed intall telling me another version of this product is already installed. Well there are many versions of Visual C++ installed, but none that match what it's trying to install.
If I try to jump right to qDslrDashboard.exe I get an error that api-ms-win-core-winrt-l11-0.dll is missing. Like I'll ever find that.
Any idea how to get it to install?
Re: Install Issue(s)
Here is an archive with the missing dlls for the WIndows 7: https://drive.google.com/file/d/1WGyrGm ... sp=sharing
Please extract these files into the qDslrDashboard folder.
lokatz
Post by lokatz »
I just ran into the same problem but the link to the DLLs has expired. Any chance you could make them available permanently somewhere? Thanks in advance.
lokatz wrote: 25 Jul 2019, 16:38 I just ran into the same problem but the link to the DLLs has expired. Any chance you could make them available permanently somewhere? Thanks in advance.
Still works here.
ringo-san
Post by ringo-san »
I have the same problem as "AndyPost".
-> Installation of qdslrdashboard on Windows 7-64bit.
Visual C** (vcredist_x64.exe) is installed. However, when qDslrDashboard.exe is started, the "api-ms-win-core-winrt-l11-0.dll is missing" error appears.
The link to the DLLs has been expired.
Can anyone help?
Thanks in advance.
zom
Post by zom »
hubaiz wrote: 16 Nov 2019, 16:26 Here is a newer Windows build: https://drive.google.com/file/d/1hMHE8d ... sp=sharing
I am a Windows 10 user and had the same reported C++ problems when I tried to install. I just downloaded the files at the Google Drive destination pointed to in the post from hubaiz and the installation worked fine.
Thank you for your effort hubaiz.
richardarowe
Post by richardarowe »
Hi. So I am trying to run qDslrDashboard on a Windows 7(64) system and I run into the same issue as AndyPost; that the api-ms-win-core-winrt-l1-1-0.dll is missing. I have tried everything I can think of including downloading the x64 and x86 redistributables from Microsoft. All the links in this post have expired or do not point to a valid endpoint. Any help you can offer will be greatly appreciated. Rick
Use the build from the previous post, that already has that dll included in the zip file.
samantha1
Post by samantha1 »
hallo
page not found
