Page 1 of 2
Help runing TP Link TL-MR3040 with my Canon 5DM3
Posted: 20 Jul 2019, 15:51
by YpsJem
may someone can help me to get the TP Link TL-MR3040 running with my Canon 5DM3 ?
How to install "ddserver OpenWrt firmware" ffrom download here and get running?
Thanks for support.
Jem
Re: Help runing TP Link TL-MR3040 with my Canon 5DM3
Posted: 20 Jul 2019, 20:05
Please check the insrructions here: https://dslrdashboard.info/tp-link-mr30 ... wrt-flash/
Posted: 22 Jul 2019, 22:54
by YpsJem
Thank you. It works.
May you have also an instruction to install the "DDServer OpenWrt" and the "DDServer OpenWrt MR3020 FACTORY" and "DDServer OpenWrt MR3020 SYSUPGRADE" on the TP Link TL MR3020 ?
I still get the "Error 4503" while update the Firmware on web browser.
thx for support
Jem
Posted: 23 Jul 2019, 06:23
For MR3020 V1 and V2 the procedure is same as for the MR3040.
For V3 check this thread: https://dslrdashboard.info/phpBB3/viewt ... 3020#p7935
Posted: 23 Jul 2019, 16:07
by YpsJem
Thanks, but i got this Error 5403, when i install the same procedure like mr3040.
i tried the firmware factory and sysupdate for mr3020 and i tried firmware for mr3040.
I have the mr3020 2V and still got following message:
Error code: 4503
The uploaded file was not accepted.
thx for support and help
Jem
Posted: 23 Jul 2019, 20:19
The MR3040 images will not work with a MR3020 device.
Are you sure it is a MR3020 V2 and not a V3?
If it is a V2 then the MR3020 image at https://dslrdashboard.info/downloads/
will work.
Posted: 23 Jul 2019, 20:33
by YpsJem
yes, sure mr3020 v2
firmware update and sysupdate are now completed. I switch power off after every step, so update fits.
But now the cam does not connect via usb kabel and the usb port of the mr3020. I got the mesaage in the app controlmycamera:
DDserver not found, connecting to IP: 192.168.1.1
List connected DSLR at IP: 192.168.1.1
Jem
Posted: 24 Jul 2019, 07:37
Please check this thread: https://dslrdashboard.info/phpBB3/viewt ... f=5&t=2101
to diagnose ddserver problems.
Posted: 24 Jul 2019, 19:15
by YpsJem
hubaiz wrote: ↑24 Jul 2019, 07:37 Please check this thread: https://dslrdashboard.info/phpBB3/viewt ... f=5&t=2101
Thanks but didn’t found Infos about the ddserver.
I got this info when i put the cam via usb at the mr3020 in the system log:
ID Time Type Level Log Content
1 2016-01-01 01:05:00 3G Information Hotplug: id[0]=04a9_323a, class[0]=storage, action[0]=add
May you can help?
Thanks 4 Support
Jem
Posted: 25 Jul 2019, 08:24
Maybe some screenshots?
Do you have the ddserver package on the System->Software page? (screenshot)?
The system log last 10 lines after you connect and turn on the camera with USB to MR3020?
